Scratch Build – In Progress Woody by zwiks
Discussion in 'Project Logs' started by zwiks, 5 Jan 2008.
  1. mvagusta
    mvagusta Did a skid that went for two weeks.
    24 Dec 2006
    So it's called "woody" and there's white in a couple of places.... :worried: well at least someone had some fun.
    Case is looking great, keep it up, looking forward to seeing it finished :thumb:
  2. zwiks
    zwiks My avatar: :D
    2 Jan 2008
    Yeah .. give me some time guys, and i fix it ! :p and thanks for the comments:p its great guys :p:D
  3. zwiks
    zwiks My avatar: :D
    2 Jan 2008
    Update.. time to get creative !
    Yeahh its update-time .. !!! :lol:
    First i cutted a pice of paper out, and painted it orange like the case: (Got the idea from the project log "Big thing")
    Then i cutted zwiks out.. (on some orange sticker)
    And now to the most nice .. (i think:D)
    Some more:
    And some more:
    Thats all.. Comments would be nice :D
  4. jhanlon303
    7 Sep 2006
    This is cool. Maybe do something about the chrome screws? Blue like the grill or fan colour for nice contrast?
    John
  5. zwiks
    zwiks My avatar: :D
    2 Jan 2008
    yeah .. you have a point !
    i was thinking of buying:
  6. theAlien
    theAlien I know what a Dremel is....
    20 Aug 2007
    that case looks very good ........... :thumb:
    but maybe paint the parts of the case that are covered when closed....the edges now visible.....
    Alan
  7. godmonkey
    godmonkey What's a Dremel?
    14 Jan 2007
    The red look HOT! :rock: However, the original paint job would have worked if you were going for a more industrial/gothic look just replace the plexi window with a wire mesh and a few metal bits... (hmm maybe I should try this...:naughty:)
    Keep up the great work!:clap:
  8. Matrix-D
    Matrix-D I know what a dremel is...now what?
    3 Feb 2008
    Just a warning. I bought those AC RYAN painted fan screws once and they are the most useless pieces of crap I have ever seen (at least my batch was). The paint was badly applied, scratched easily, and, worst of all, the screws were of such low quality that I couldn't even screw them all the way into a fan. It's possible that my shipment was an anomaly, but I think you might be better off just painting the normal screws yourself. You can just stick them into some cardboard, hit them with a layer of primer, a few layers of blue paint, let them cure for a few days and you're good to go.
  9. zwiks
    zwiks My avatar: :D
    2 Jan 2008
    Thank you guys for youre comments.. you rock ! :rock: :D
    As regard to the edges, my idea was actually to paint them .. and I´m doing it very soon ... :D
    ^^Yeah .. nice tip.. I´m doing it very soon^^
    .. must go now.. have to :dremel::dremel: a bit :D
  10. zwiks
    zwiks My avatar: :D
    2 Jan 2008
    Small update..
    Yeah.. small update [10-2-2008]
    Using some tape ..
    And painting..
  11. eXplode
    eXplode sound freak
    1 Dec 2007
    I realy like the "warm orange" colour. Looks really good on ur case. Keep it up.
  12. jhanlon303
    7 Sep 2006
    I bought a brand new Hemi Roadrunner in 1969 that was bright orange with a black interior. 1st class chick magnet. Anything orange and black rocks me.
    This is coming along nicely.
    John
  13. zwiks
    zwiks My avatar: :D
    2 Jan 2008
    yeah orange is a nice colour.. and thanks for youre comments guys.
  14. zwiks
    zwiks My avatar: :D
    2 Jan 2008
    Gimme Gimme..
    I would like to call this update for:
    Gimme Gimme..
    Cuz i dont have the money right now, but I´m gonna work my **Beep** of, to get this nice hardware.
    I´ve just found some hardware for the case !. (Water-cooling is not on the list, but its my plan to put it in)
    So here it is ... [Gimme Gimme..] :D:D
  15. jhanlon303
    7 Sep 2006
    Nice shopping list. Always had good luck with ASUS myself. Remind me not to take you to the grocery store when you are hungry:thumb: Keep going we are watching.
    John
  16. zwiks
    zwiks My avatar: :D
    2 Jan 2008
    thank you John
  17. Fozzy
    Fozzy What's a Dremel?
    25 Jan 2005
    cool on the paint job, I've seen that rooler way before with some light sanding in between. I would still finish it off with a clear coat for some protection.
  18. zwiks
    zwiks My avatar: :D
    2 Jan 2008
    thank you fozzy.. i am going to give it some clear coat.. but its not because of the protection of the paint-job.. its only for the look... cuz the orange-paint i used, it the same paint you use in kitchens, so its hard like he*l :D
  19. zwiks
    zwiks My avatar: :D
    2 Jan 2008
    Things to do:
    Things to do:
    Paint this [Orange like the case]:
    Use this to scrape the paint left overs:
    Scrape this off:
    Fix/paint [Black] this:
    Cut off the red area:
    ^^I´m doing it tomorrow^^
    by the way: Jubiiii 100 replys :D hehe "loool"
  20. zwiks
    zwiks My avatar: :D
    2 Jan 2008
    Question..
    Tiny update
    or, it isen´t a real update.. Its just a question:
    I´ve just recived these, can i use them someway in the project??
