Other Word-Help with removing unwanted spaces in text
Discussion in 'Software' started by greshoff, 30 Dec 2011.
  1. greshoff
    greshoff Minimodder
    29 Dec 2004
    My daughter has written an essay which contains some pictures as well as text. The line spacing is set to 1.5. She removed some text from the document and now there are large white spaces between some of the paragraphs/ text. Not the line spacing, this is OK. If one goes to the end of the text before the unwanted space and clicks delete the space disappears but if one clicks return to create a new paragraph the space returns. The doc was written using word 2007. I am sure this is something fairly simple to solve. Any help will be much appreciated. Thanks
  2. longweight
    7 May 2011
    Go to page layout on the ribbon and adjust the spacing before / after to 0cm.
  3. greshoff
    greshoff Minimodder
    29 Dec 2004
    Doing this does not correct the problem. Any other ideas?
  4. SuicideNeil
    SuicideNeil What's a Dremel?
    17 Aug 2009
    Select all & resize the text ( I like 10 or 12 generally )- the large white spaces may be set to a larger font size, or some't like that.
    I'd also suggest opening & editing the document in a program like Open Office writer- free & almost as good as a modern copy of Word..
