Build Advice Work Computer Build Advice
Discussion in 'Hardware' started by dugnas, 29 May 2017.
  1. dugnas
    dugnas New Member
    27 Nov 2008
    Hey,
    It has been quite a while since I last wrote something here and everything moved so far through these years so I guess the easiest is to ask you about what parts should I buy for my new build than try to catch up with all this new computer tech.
    So I need to build a new computer for my mum. It will be used mostly for accountant stuff. The budget for this is about 300-450 pounds without the monitor and I think I will find an old case lying somewhere around so no need that also (but you can try to convince me that I need a new one). Oh and I think the computer should have a small SSD for OS and a bigger one maybe 500gb-1tb ordinary one for data but also you can ignore that also.
    Thanks in advance.
    Cheers,
    Justas
  2. Mongoose132
    Mongoose132 Duckmad
    23 Aug 2007
  3. mrbungle
    20 Sep 2004
    G4560 is stupidly quick for a £50 CPU.
    Anything built around that would be my bet.
  4. MSHunter
    MSHunter Well-Known Member
    24 Apr 2009
    Referb HP elitedesk with i7. Comes with win 10 and even office if you look around the bay. Perfect for office work.
    Sent from Bittech Android app
