Case Mod - In Progress [Worklog] Dragon Beast
Discussion in 'Project Logs' started by aRkangeL, 3 Oct 2012.
  1. aRkangeL
    aRkangeL MegaRUSH
    29 Nov 2010
    Thanks this is just the best way to sleeving, and my best work too.
  2. andybones
    andybones What's a Dremel?
    1 Sep 2008
    Superb job,makes the finished job look more professional ;)
    Andy
  3. aRkangeL
    aRkangeL MegaRUSH
    29 Nov 2010
    Thanks Andy,
    Pls Dont look at the liquid, there is a chemical problem on the loop, i will fix it soon as i can.
    That sleeved cables on its place look really good i think, and now i have to way for the custom front, and top grill, and its done.
    After that i will just add some little things more, and change the liquid ofc.
  4. ziza
    ziza What's a Dremel?
    21 Dec 2010
    Wow the sleeve looks really sweet :jawdrop:
    The WC management is really good, I just do not like the PSU cables over the reservoir, but that it is only a matter of taste.
    You are really changing the modding quality in Portugal keep it up.
    regads,
    ziza
  5. aRkangeL
    aRkangeL MegaRUSH
    29 Nov 2010
    Thanks Ziza,
    Yes the WC, are really cool i just dont like thing, the pumps should be more compact, and more quiet, so maybe when i can i will change it for two 655, with dual serial top.
    No I dont believe, im not changing anything, i just doing my projects as i would always do, people in portugal dont believe to much in this kind of hobby, and they dont care to much about it.
  6. KoSoVaR^
    KoSoVaR^ Professional Sleever & Modder
    19 Dec 2010
    what happened to the black coolant :O?
  7. aRkangeL
    aRkangeL MegaRUSH
    29 Nov 2010
    Black?!
    Who says was black?
    Was pastel red, but if lower PH on the system the liquid color turn into this.
  8. KoSoVaR^
    19 Dec 2010
    hmm, i thought you had black :p
    Have you used tapwater xD?
    WHy arnt you using biocides bro?
  9. aRkangeL
    aRkangeL MegaRUSH
    29 Nov 2010
    Yes have i, and i have talked with mick, and its all good now, we have located the problem.
    Because mayhems already have it on.
  10. KoSoVaR^
    19 Dec 2010
    Ahh nice to hear :)
    What was the problem btw?
  11. aRkangeL
    aRkangeL MegaRUSH
    29 Nov 2010
    Yep i will flush the system with Bi, and Di water, and will use the new XT-1 fluid concentrate.
  12. aRkangeL
    aRkangeL MegaRUSH
    29 Nov 2010
    Almost the last one (I hope)
    More sensors, some to change, others to add, but always something to do.
    But when we think that its all here, we have always something missing.
  13. KoSoVaR^
    19 Dec 2010
    looking good dude !
  14. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    Really looking forward to seeing the colour of the new coolant - the old one turned pretty bad. ;)
  15. aRkangeL
    aRkangeL MegaRUSH
    29 Nov 2010
    Thanks guys...
    time for news
    Im back with great news, from the paper to the real life, seems pretty good to me.
  16. KoSoVaR^
    19 Dec 2010
    AWSOME PART BRO !
  17. aRkangeL
    aRkangeL MegaRUSH
    29 Nov 2010
    Just like i think man! :D
  18. Azariel
    Azariel What's a Dremel?
    23 Oct 2008
    Looks awesome! Love how both the lettering and the logo is backup by that deep red plate behind it.
    I assume the larger white part is to create some sort of 'light box' behind the logo & lettering?
  19. aRkangeL
    aRkangeL MegaRUSH
    29 Nov 2010
    Yes it is, and i cant wait more, to turn ir up.
  20. KrunchR
    KrunchR What's a Dremel?
    22 Apr 2008
    Awesome work!
