Case Mod - In Progress [Worklog] Lian's Spirit
Discussion in 'Project Logs' started by Bumbeldi, 10 Apr 2011.
  1. Bumbeldi
    Bumbeldi What's a Dremel?
    10 Mar 2011
    Hi folks, I'm to present you my new project :)
    This will be a long term project, without any prediction of when is ready.
    I'm gonna start to adventure into a new world of modding where all work will be done by me.
    I will use machinery that had never tried before, so i have still to practice to become the results that i pretend.
    The project consist in a full interior reconstruction and paint job of the chassis
    Didn't have nothing programmed for the hardware, only the WC system is more or less defined.
    I pretend to mount two 240mm radiators on the bottom and maybe one 120mm rad next to the board.
    I intend to create a system ready for dual loop, but that are still things I have study before.
    Leaving the conversation and passing to the photos:
    My workshop where all the work will done
    However got a lot of work to do, first thing to start will be the "middle" tray divides Psu / radiators of the rest.
    Acrylics i will use and Tray + tray holders already cut out.
    Basically most of the interior will be white acrylic with some parts in black too
    Already in test and measurement
    Still under development, Hdd cage for 3 discs with Hot-Swap system
    two new toys, sander and drill
    M3 screws, countersunk and button head
    Rivet countersunk and dome head
    HDD cage already in final state
    Holders for the Hot Swap connectors
    Middle tray holders already finished
    The mess after some work, acrylic everywhere :D
    Middle tray already fixed and one of the rad supports done, just missing three more :confused:
    3 router bits, radius round over and straight cut
    Acrylic with 1 cm of thickness just for a quick test
    After a couple of minutes sanding with a 1200 grit.
    Just need some polishing and pass a bit with a blowtorch to make it shiny again
    tray guide, made for easy remove of the board tray like lian li style but more beautiful....:D
    Guide already fixed and tray on his place
    Brackets for the radiators finished.
    Made in order to give more stability to the middle tray, just missing to fix the brackets on the bottom and ready to mount the rads
    New part that divide the mobo from the hdd / 3.5 drive bays
    Comb for 24 pins cable, to make a better cable management and give a more cleaner look as well
    Some led's to make it shine
    And one more comb for 8 pins connector
    kind of a gutter that stays between the rads to give a better cable management
    Middle tray finish
    I hope you guys enjoy my work, ive got still a lot to do to have this build finish...:thumb:
    Best regards
    Bumbeldi​
    David and Nanosec like this.
  2. KidMod-Southpaw
    28 Sep 2010
    WOW, I love the piece for the 24 pin, I'm very impressed, can't wait for more!
  3. Bumbeldi
    10 Mar 2011
    Thanks mate! :)
  4. Trance
    Trance Two steps forward, one step back
    6 May 2009
    What a great first post, love the attention to detail and superb plexi work. Can't wait for more ;)
  5. Stem83
    Stem83 Addicted to modding.
    26 Mar 2011
    Total quality...looks so pro. keeping glued to this one..
  6. -Jv-
    -Jv- What's a Dremel?
    29 Mar 2011
    This looks great, if only I had the same tools I'd give it a shot too. Sub'd
    -Jv
  7. Marcos_Viegas
    Marcos_Viegas Minimodder
    6 May 2010
    Really excelente project! :thumb:
    Keep going! :rock:
  8. Blarte
    Blarte Moderate Modder
    15 Jul 2008
    this is looking special
  9. Fedmas
    Fedmas Leader of the casemod watchers :D
    29 Jan 2010
    OMG OMG. Nice! really nice
  10. THP Dan
    THP Dan What's a Dremel?
    21 Jul 2009
    Very nice work!! Cant wait to see more.
  11. AnG3L
    AnG3L Ultimate Modder
    19 Mar 2009
    Really nice work my friend, I see a kick ass mod coming our way!!! :)
  12. nagyizom
    nagyizom Minimodder
    2 Jun 2008
    Nice work so far, I'll watch this:dremel:
  13. Bumbeldi
    10 Mar 2011
    Thanks, great to see that you guys are enjoying my work...:thumb:
  14. djzic
    djzic Bokehlicious!
    8 Nov 2010
    Very nice, I'm watching :thumb:
  15. cool_dude
    cool_dude Minimodder
    26 Aug 2004
  16. Genghis
    Genghis What's a Dremel?
    8 Apr 2011
    ouaouh !!!
    great work here. nice ideas for cable management.
    a plexiglas artist for sure
  17. SPNKR
    SPNKR Pretty Good Kid
    22 Feb 2010
    I'm honestly blown away by the quality of your work so far, it is like Atilla but with acrylic. I love all the custom parts, even for things that won't be seen like the cable channel.
    I will be following this log with great interest!
    Have Fun,
    SPNKR
  18. Nanosec
    Nanosec absit iniuria verbis
    28 Apr 2009
    sub'd and +1
    Nano
  19. Bumbeldi
    10 Mar 2011
    Thanks guys, i appreciate...:)
    I have no idea where you can buy a router in uk, in a good tool shop you can buy it for sure.
  20. Chairboy
    Chairboy I want something good to die for...
    10 Jun 2004
