Case Mod - In Progress [Worklog] Project:Black Fire, Update:31 Dec 2007
Discussion in 'Project Logs' started by lolhalol, 20 Nov 2006.
  1. lolhalol
    lolhalol What's a Dremel?
    20 Nov 2006
    measuring the line sfor the top panel acrylic.
    marked
    drilled the holes for the bolts.
    test fiteed, perfect fit. the coulour of the bolt is temporary untill i can source beter ones. these ones someof them have fitting problems.
    drilled the holes on the panel. its very very hard to get the holes perfectly right. dam drill bit was jumping a lot due to the bent panel.
    some shots of it fitted and how it should look.
    [addedon]January 31, 2007, 3:24 pm[/addedon][​IMG]
    the bolt that secures it.
    well thats it for now, im really tired after a full day of testing hardware for my self. but i might do something later..
  2. B[x]
    B[x] What's a Dremel?
    3 Jul 2006
    I've been keeping my eyes open for these for awhile but just can't seem to find a place that sells them (at least in well documented form). You mentioned that you were going to look for a different source of these finishing washers. If you happen to find them online anywhere, please let me (and the rest of the community) know where. For the time being would you mind giving us the dimensions of yours such as their height, outside diameter, and what size bolts they fit? Thanks.
  3. lolhalol
    20 Nov 2006
    bro i will measwure it tonight sorry didnt see ur post untill now, but will post it tomorow or monday if that ok with u....sorry yeah
    update...
    got the stencils cut by a roland sticker cutter...
    the mod as it is since the last update...
    cut out on section of the flames needed... u dun want to screw up the other parts do you...
    stuck in on to the top panel. marked up all the lines and stuffs.
    masked the flames so that i can see it later after a coat of black.
    my paint "collection"
    as you know byy now my tool of choice , the spray gun.
  4. lolhalol
    20 Nov 2006
    first coat of black
    another shot of it..the nice thing bout painting acrlics is that u dun hav to worry bout snading and all that... but u have to be carefull at which layers that paint will go on as it is a mirror efect if u flip the panel..like i do. if u dun understand i also dunno how to explain... sorry...
    ready for orage coat after stencill is removed...
    sorry i totally forgot to take pics of the orage coat...i totally forgot, ...but its standard affai...so i dunt think it will be needed right..
    one last overcoat of black...
    and the clear coat to seal it...
    now for finish...
    it hasent really driend enough for me to handle so more pics up the next update...
    p/s hope u guys like the new pictures with the better camera...
  5. Jipa
    5 Feb 2004
    Thank you so much for starting to take the pics with a decent camera! Now I can actually see something and not just read throught the expalanations and try to figure out what you've done! :) I'm a noobie when it comes to painting, but it's good to see you pulled that off nicely.
  6. bubsterboo
    bubsterboo What's a Dremel?
    24 Jan 2006
    I like!
    The more i see these great project logs, the more i want to do my own.
  7. lolhalol
    20 Nov 2006
    sorry for being away for a while ,my local lanparty has inspired my lazy butt to start modding again..will mod when my new dremel arrives..right now still dam tired... anyway i have purchased my new psu for this mod... from performance pcs... heres a link to it... http://www.sunbeamtech.com/PRODUCTS/Power-...UO/nuuo-550.htm might be old (circa 2005) but its grweat value for money and has a beautiful polished finish and is modular... :)
    http://pcmoddingmy.com/e107_plugins/conten...p?content.251.6
  8. lolhalol
    20 Nov 2006
    hey guys , not much modding going on, but i have been acumulating my parts for the up coming moding...
    my new dremel
    wats in teh package, i chose the most basic package as i wont be needing all teh other accesories , to keep costs down....
    and this is a small surpirse.... i went and got a ACryn mesh panel, thx coolice, costs quite a lot but looks realyl nice....
    here teh pics...
    thats all for now.... thx for reading and all teh great coments...
  9. lolhalol
    20 Nov 2006
    samll updates, still collecting the parts for my mod, just recieved my cutting discs from bombman, thx dude, and some dremel parts will be arriving soon , anyway heres teh pics
    a small package indeed
    teh cutting discs,
    thats all folks...lol...sorry its suxch a small upadte..,.. i apologise for the crappy picture quality, took it in a hurry
  10. ezland00
    ezland00 What's a Dremel?
    22 Jul 2005
    Nice decal
  11. lolhalol
    20 Nov 2006
    small update.... got even more new stufs....lolz....
    razer death adder
    razer exactmat with arm rest
    dfi rdx200 cf dr
    and a new dvdrw....
    also got a small package from usa, dremel stuffs have arrived :idea: :idea: :hyper: :hyper:
    my flexi shaft
    Keyless Chuck
    Dremel cutting discs set
    thats all for now...lolz
    still no modding...haha just collecting...
  12. lolhalol
    20 Nov 2006
    ok some updates on hardware.... i have bought some new wc cooling kits.... and a vantec vortec hdd cooler....
    wc kit is as follows:-
    D-tEk fuzion
    DB1 Compact Low Noise pump
    Cooling Works Coolrad 22t 2x120 Radiator
    Danger Den Fillport
    Tline barbs
    Tubings haven decided yet...
    and a vantec vortex hdd cooler...
    also theres a slight posibility of me geting a dfi expert.
  13. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    that case looks really good
    Edit : Get tygon tubing
  14. lolhalol
    20 Nov 2006
    @the_beast
    thx mate.... yeah thinking of getting tygon... but it will be down to the matter of availability.... coz where i live tygon is rare...have to take an order out from USA . shiping is gona be a killer ...
    some pictures of new stuffs...again...
    got a fluid xp vortex... same as the dtek fuzion... will be geting the ori dtek fuzion later ... want to see the diference between the two...hehe
    and i got my dfi expert.... :thumbs: :thumbs:
    remember the vantec vortex hdd cooler? heres the pictures...
    went and got myself a hr-05 sli for the expert....
    its ontop of the box of my hr-05 ...haha
  15. lolhalol
    20 Nov 2006
    ok finaly updates...and its gona alot of pictures.... hehe :thumbs: :thumbs:
    here we go...
    ok first i got a new case to be the main case, im cahnging plans from a single case to a dual stacked case...so teh old case i had before willbe cut in half and mounted to the top. of teh this case... this case bought form irangan for such a ncie price..thx pal...
    heres the old case , which has been wraped in plastic for the last two months :cry: :cry: sorry pal...
    i also bought a pratorian case, aka atcs coolermaster which looks so sexy... but this is for another mod so look out for it...
    found this in my store room, dunno is it called..but its usefull...
    thx coolice for borrowing me ur jigsaw
    here we go with the case
    stripping it down
    teh panels removed
    teh front removed
    top removed and standin next to the old case ...
    removing the hdd cage
  16. lolhalol
    20 Nov 2006
    taping up a line for cuting the nothch to fit a thermo and panaflow later,...
    warming up the flexi shaft as recomended....
    a few minutes later
    cut a preety straight line, nt bad for my first ever use of the dremel...
    now using the jigsaw i cut the rest off
    done...
    sanding the edges so i dun cut myself
    preparing to rivet back the case
    ohh did i mention i cut the front of like the last time
  17. lolhalol
    20 Nov 2006
    here i cut of some areas which the jigsaw accidently dammged... while also taking out one of my tooth :cry: :cry: now i have to visit dentist after this...... but i think i manged to salvage it well.. dremel saves teh day... :thumbs: :thumbs:
    gave it a nice shower , to get rid of all teh dremel cuting disc dust and watnots.... and prep for tomorow , painting the base coat..
    and some new toys to play with...
    best pic i took the whole day...
  18. 500mph
    500mph The Right man in the Wrong place
    22 Jun 2007
    this looks like it will turn out to be a great mod! and i like the cut vinyl
  19. elbarto241
    elbarto241 What's a Dremel?
    12 Sep 2006
    that thing that you found in your store room is called a table vice, helpful indeed for the modding process. those are some clean cuts for your first time, keep it up. :D
  20. lolhalol
    20 Nov 2006
    updateszzzzzzzzz... loads of pictures.... this willa ctually be a dual update for todays worth of work as photobucket wasnt working for a while...
    here we gooooooooo....
    geting ready to make the new face plate....
    measurements and lines done...
    holes of where to drill marked
    used a pin thing to punch a small hole where the holes are to be drilled for acuracy
    first part done
    all the holes done
    using the jigsaw to cut out the fan holes...
    halfway there
    done
    cut out the cd bay
