Case Mod - In Progress [Worklog] Purple LI
Discussion in 'Project Logs' started by aRkangeL, 29 Nov 2010.
  1. aRkangeL
    aRkangeL MegaRUSH
    29 Nov 2010
  2. aRkangeL
    aRkangeL MegaRUSH
    29 Nov 2010
  3. Stem83
    Stem83 Addicted to modding.
    26 Mar 2011
    like the multi color sleeve. nice build.
  4. Hannes
    Hannes Design | Art | Performance
    24 Apr 2010
    Can't say I am. :eyebrow: You still have some work to do before I join your fan-club. :lol:
    It seems to work out well for you Tiago, keep up the good work.
  5. aRkangeL
    aRkangeL MegaRUSH
    29 Nov 2010
    Lool thanks man you are my hero ahaha:D
    Make some time since last update so;
    here is some photos!
    And here is my new facebook page all about modding x) Link
  6. aRkangeL
    aRkangeL MegaRUSH
    29 Nov 2010
    So for a long time that i dont update this thread, and now I took some photos to show the new CPU block.
    Next update will be the front costum filter that I done on the CNC and on the future i want to change the liquid for some mayhems mix.
  7. Sheiken
    Sheiken Wat?
    9 Jan 2005
    Well, I can only say that Hannes definitely should join your fanclub! Looks awesome!
  8. aRkangeL
    aRkangeL MegaRUSH
    29 Nov 2010
    Mine?! why? His work looks better than mine no?!
  9. Sheiken
    Sheiken Wat?
    9 Jan 2005
    His photography skills might be better, but I prefer your work :) Yours is also finished, lol! :rock:
  10. aRkangeL
    aRkangeL MegaRUSH
    29 Nov 2010
    Lol Ok thanks m8...
    This case its finished but as you know it always have something to improve!
  11. Hannes
    24 Apr 2010
    Of course not. :) Your work is splendid. :thumb:
  12. aRkangeL
    aRkangeL MegaRUSH
    29 Nov 2010
    :worried::worried: Thanks :clap:
  13. aRkangeL
    aRkangeL MegaRUSH
    29 Nov 2010
    Som new things to come in... in a few days maybe.
  14. aRkangeL
    aRkangeL MegaRUSH
    29 Nov 2010
  15. aRkangeL
    aRkangeL MegaRUSH
    29 Nov 2010
    Final photos pls coment :D
    rak500 likes this.
  16. rak500
    rak500 Member
    22 Aug 2009
    IMO, the white coolant works better, gives it a more solid look somehow.
    I'm glad to see this again, the attention to details is just oh so very good.
    Nice! Have some rep!
  17. Shurika
    Shurika Member
    9 Mar 2012
    awesome work, mate! I love this project, but... why you didn`t heatshrinked every wire on 24-pin?
  18. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    That book case looks HUGE!!!! The casemod appears as if its owner (Frodo) brought it to Gandalf's crib?
  19. KiiYzOo
    KiiYzOo New Member
    11 Mar 2011
    nice :D are those 120mm phanteks? if they are, then I'm happy that it is possible to get them as the 140mm ones that I have are awesome :D
  20. aRkangeL
    aRkangeL MegaRUSH
    29 Nov 2010
    Thanks mate, about the coolant im thinking in buy some purple dye from Mayhems to give some color to this.
    Thanks man, I have but the 24 pins cable of this PSU its the same as the Corsair AX and other made by Seasonic, and the conector who fits on the PSU have about 30 pins and finish with the 24 on the mobo, so I have 2 wire per pin and i cant fit them on the conector its why it looks a little bit bad...
    Thanks mate, i dont know very much what are you talk you about but for sure is a good thing :D:thumb:
    Yes man they are de 120mm ones, they look really cool, and performs really well.
