Case Mod - In Progress [Worklog] Rebuilding an old companion Project ‘Battlefield’
Discussion in 'Project Logs' started by ivory2k19, 6 Mar 2026.
  1. ivory2k19
    ivory2k19 Minimodder
    8 Feb 2019
    Part 2
    I glued the whole thing together with Pattex assembly adhesive and filled in any gaps with a bit more plaster.
    Painting it turned out to be a bit of a challenge right up to the end, but with the help of a few videos, I managed it in the end.
    I used light colours like red, yellow and orange as the base, then added a few strokes of black paint diluted with water, and finished by dry-brushing with stone grey.
    All the paints are acrylic and washable with water.
    IMG_20250928_222002.jpg IMG_20250929_205926.jpg IMG_20250929_222230.jpg IMG_20250929_222248.jpg IMG_20251006_222922.jpg
    Not quite what I’d had in mind, but the more you look at it, the more it actually fits the overall look.
    I also added a bit of ‘landscape’ – as you’ve already seen, the barrels and AKs are set in a meadow.
    For this, I used grass from model-making kits.
    The side of the CPU also needed something special back then, still in the Stalker style
    An update on the case is coming soon; I’ve also got some feedback on Distro that isn’t exactly great... xD
  2. ivory2k19
    8 Feb 2019
    I’ve got a quick update on the Distro for you.
    The design is now complete and everything has been finalised; there’s already plenty of resin available – it just needs to be printed.
    Here’s the old design for comparison
    Here’s the new one for comparison. The Tank is now positioned directly on the pump, so that should sort out the problem with filling it up.
    These are screenshots, not rendered images, as you can’t see them very well otherwise… xD
    Cheapskate likes this.
