Build Advice Workstation & Gaming Rig (£1600.00 Budget)
Discussion in 'Hardware' started by Modsbywoz, 26 Nov 2018.
  1. Modsbywoz
    Modsbywoz Multimodder
    14 Oct 2009
    Okay, so it's finally time to look into buying a new workstation/gaming rig for the home office.
    I have set a budget of £1600.00 but this can be stretched if needed but ideally 1600 is the target.
    Main uses include;
    Gaming (CS:GO mainly but looking at other titles like BF5..)
    Photoshop & Lightroom (work related)
    Office Suite
    Adobe Suite (inc. Premiere and Dreamweaver)
    Requirements;
    Base station only, no screen, keyboard/mouse required.
    500gb m.2 drive as primary drive.
    Minimum 16gb ram
    Minimum 4C/8T processor due to work multitasking.
    USB3.1/Thunderbolt due to loading large files onto disk.
    Overclocking (not a necessity as reliability will far outweigh slight performance increase)
    Must be quiet, so AIO coolers/watercooling an option.
    GFX must be able to run GSGO comfortably but also run BF5 or similar.
    I hope this gives you all the information needed and thanks in advance.
  2. meandmymouth
    meandmymouth Multimodder
    15 Sep 2009
    What resolution are you gaming at?
  3. Modsbywoz
    14 Oct 2009
    1080p currently however looking to buy a 1440p 144hz monitor early next year.
  4. The_Crapman
    5 Dec 2011
    I've picked out 2 rigs:
    Workstation focused threadripper build with 1920X and gtx1070ti £1599.08
    Graphics focused with a 2700x and rtx2070 £1648.39
    I've tried to keep it to things in stock (but you may shop elsewhere) apart from the m.2 drive which only realised now isn't. I've not included hdd's as have presumed you have some to carry over?
  5. Modsbywoz
    14 Oct 2009
    To be honest, the second graphics focused spec looks much more suitable for the additional £50.
    Thanks for the help. :)
  6. meandmymouth
    15 Sep 2009
    You could save yourself £70 on that spec by not getting the Corsair cooler. The 2700X comes with a decent cooler in the Wraith Prism.
  7. Modsbywoz
    14 Oct 2009
    Noise is however a concern as the PC will be left running 24/7 in our unused bedroom and I've grown out of putting up with trying to sleep while fans are screaming. I think the AIO should help with that.
  8. fix-the-spade
    fix-the-spade Multimodder
    4 Jul 2011
    A beefy air cooler will be quieter than an AIO. Noctua and Be Quiet are the usual go to coolers, all in one water coolers tend to make a relatively large amount of pump noise. If you leave it rendering overnight any system will wail at you.
  9. Modsbywoz
    14 Oct 2009
    The computer is left on overnight purely to make backups of online servers. To be honest, I may go the air cooling route as I will not be looking to overclock the cpu considerably.
  10. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    For those tasks Threadripper would be a massive waste of money, as even the 8700K wipes the floor with the lot of them. All of those use cases demand high single-core speed over more cores, so the 'optimum' CPU would be something like the i9- 9900k (or its upcoming Xeon-E equivalent if you want ECC).
  11. Anfield
    Anfield Multimodder
    15 Jan 2010
  12. damien c
    damien c Mad FPS Gamer
    31 Aug 2010
