World War II radiomod [CIP] update 22 june (hw mounted + jeep :) )
Discussion in 'Project Logs' started by saiko, 31 May 2007.
  1. saiko
    saiko What's a Dremel?
    16 Aug 2006
    I have been working on this mod for almost 2 years. I advance realy slow because it's a low priority for me at te moment.
    the idea is to mod a normal PC in a World War II radio. I'm building the case for someone else who loves to play RTCW:ET.
    At this moment the case is almost finished but some details still have to be done.
    that was how she was looking before I started.
    Nothing in the front will be changed.
    first thing to do :
    make a normal ATX motherboard fit.
    so I took everything out.
    and made a new frame using as much as possible from the original case.
    cleaning up the front
    and try to fit in a motherboard tray
    close call but it fits
    more Soon
  2. fungry
    fungry What's a Dremel?
    14 May 2006
    an interesting idea but i think a redone frame would have been better. though, that would complicate things as you would then have to remove and remount the radio's front panel.
    wish you the best of luck on this mod. i like that ww2 radio :D
  3. malccy72
    malccy72 Minimodder
    9 Jan 2005
    Have always wanted to do a similar mod myself so will be watching closely.
  4. Xlixen
    Xlixen What's a Dremel?
    16 Apr 2007
    Loving the idea, Looks a lot of work. Good luck :)
  5. saiko
    16 Aug 2006
    every switch and light in the front will be reused
    I started with the power and HD -led
    and connected
    then some led's in the front. I used amber colored leds they give a 'warm light' like old lamps.
    in the dark
    In the upperright there was an old Voltage meter. I have been searching for the right resistor for some day's. But I found it
    (not very clear but it says '12V')
    front at this moment
  6. jokkos
    jokkos too busy to mod *sigh*
    10 May 2005
    that looks good...I like the orange light
  7. fungry
    14 May 2006
    yea! i really like the orange light. its got that classical feel, old but not TOO old :D
    i like.
  8. gar
    gar Minimodder
    15 Sep 2004
    I really like this project. It actually looks really cool in that piano black colour. It looks sorta modern to me!
  9. saiko
    16 Aug 2006
    I found a new function of the fuse holder and the transmitter cabel :)
    I'll be transmitting with firewire from now on :D
  10. TNash
    TNash What's a Dremel?
    12 Mar 2007
    real cool idea!
    The amber colored LEDs look great!
  11. saiko
    16 Aug 2006
    I made a frame for the HD's and dvd-writer
    this front will be used as a dvd stealth
  12. mvagusta
    mvagusta Did a skid that went for two weeks.
    24 Dec 2006
    nice ideas, nice WWII radio. i like the amber leds. i wanna see more amber being used! a glow around each knob would be nice, an led concealed under each knob would give this effect.
    the dvd drive MUST be black however. you must buy one, they dont cost much. im sure you are gonna block the space above and below the dvd drive. a small hole with a little grommet is oneway to allow the led wires to pass.
    if the wires are just exposed, hanging under the dvd tray when the dvd is opened, it would probably blend in with the "WWII" feel of it.
    hope you make/mod a matching monitor, keyboard & mouse :dremel:
  13. nasanut
    nasanut What's a Dremel?
    4 Jun 2007
    What would be neat is to have the dial on a spring loaded hing and let the dvd open it and close it.Also do you know the model of this radio?I love this mod.I use to collect mil-radios until it took over my life had to sell them off. :wallbash: Led's behind all the knobs sounds alittle to much.you want to keep the looks as real as possible.
    Watching this mod everyday.Great work
  14. saiko
    16 Aug 2006
    The hardware you see on the pictures is just for testing.
    there will be a black dvd/writer :)
    I don't know anything about old WW2 radio's.
    on the radio there is writen "mod 125/1"
    The guy we bought it from said it was used in airplanes.
  15. dacust
    dacust What's a Dremel?
    10 Mar 2007
    For myself I think I like the whole dial coming out, even though it'll make loading the discs a little awkward. The flip down would look cool as well. As for the LEDs, you might be right there as well, but I also think having all of them lit with low power LEDs would look good.
    Basically, you may be right on both points, and I like your idea of the flip-down, but I tend to like what saiko has planned a little better.
  16. saiko
    16 Aug 2006
    new update.
    I numbered the parts so I can explain what is going to be what
    1.Audio out
    2.fancontroller can set a fan between 300 en 3000 RPM
    3.ON-OFF knop
    4.Firewire in-mini
    5.firewire in-normal
    6.dvd-stealth
    7.Radio button kind of tuner. if you turn you can search post's if you stand on a post a tune starts playing and the white LED starts burning
    8.can dim the leds
    movie about number 7
    http://users.skynet.be/p33w33//WWIIcase/Casemod.wmv
  17. malccy72
    malccy72 Minimodder
    9 Jan 2005
    Absolutely love it to bits - would so much like to have something similar.
    Well done on such a great job and for being so respectful to its heritage.
  18. unheardof
    unheardof What's a Dremel?
    3 Mar 2006
    You know what I think might look good. If you placed an optical drive vertically behind the radio dial and had a window to show the disk spinning where the frequency graph is at the moment. Althugh this would mean the drive would eject out of the top though
  19. malccy72
    malccy72 Minimodder
    9 Jan 2005
    That would completely spoil it imo - a good modder knows when to stop like a great painter.
  20. saiko
    16 Aug 2006
    this is a big update. :)
    all the hardware is mounted
    And a fotoshoot at a WW2 jeep (also modded :) for off-road use)
    some detail shots
    As you can see there is not much space for a good CPU cooler. there is only 6CM space. At his moment we have a 1U s775 cooler but he is not doing his job very well.
    The intel e6600 is running at 80°C idle.
    so the next thing to do is find a good 2U cooler or we have to adjust things.
