Worlds First Serial ATA Board..
Discussion in 'Hardware' started by scopEDog, 28 May 2002.
  1. scopEDog
    scopEDog Minimodder
    5 Mar 2002
  2. George
    George Bah
    14 May 2002
    nice!
    the problem is, just like SCSI, these new drives will cost a fortune!
    .icecube
  3. Phire
    Phire Performance-PCs.com
    11 Jan 2002
    droool....serial ata....droool......
  4. eddie_dane
    eddie_dane Used to mod pc's now I mod houses
    31 Jan 2002
    I am just pleased that the large cables are history! :D
  5. IsaacSibson
    IsaacSibson Banned
    15 Nov 2001
    Ok, forgive my obvious stupidity, but I don't see any S-ATA connectors on that board in the pic....
  6. eddie_dane
    31 Jan 2002
    I thought the same thing... but was afraid to say because the only working image of the connector was from an article on heatseekerz.net...
    and the one on here is a PCI card controller, not on-board...
  7. eddie_dane
    31 Jan 2002
    perhaps they are going to use that white connector above the RAM sockets as a daughter board like on this mobo:
    just a guess
  8. Digitalblueshift
    Digitalblueshift What's a Dremel?
    12 Feb 2002
    look beneath the ATX power connector.
  9. banished
    banished Necromodder
    6 May 2002
    yeah, I believe that's them, but weird place to put them.
  10. kanuslupus
    kanuslupus Minimodder
    10 Mar 2002
    I thought the exact same thing.
    From what I've read, the drives will be cheaper than SCSI, but more than IDE.
    Considering how cheap IDE are, I'm not overly worried. Sure, it may mean
    buying 1 at a time, but oh well. IDE begone! :hehe:
    I am looking forward to this sooo much. I've been waiting for Serial ATA to
    upgrade my system from a Slot A to a dual MP something :D
  11. banished
    6 May 2002
    How about a dual XP system? Or is your system mainly for business?
  12. kanuslupus
    10 Mar 2002
    I was under the impression running XP's in a dual system was not guaranteed to work.
    Also, I'm likely to wait until the Opteron's get some reviews.
  13. scopEDog
    scopEDog Minimodder
    5 Mar 2002
    Using older XP's will work under dual (although some boards dont support it, and AMD will not give you tech support for it) but the newer will not work. You'll have to use MP's
  14. felix the cat
    felix the cat Spaceman Spiff
    11 Jan 2002
    lets just wait for the serial hdds to come out and have a look then...
  15. scoob8000
    scoob8000 Wheres my plasma cutter?
    17 Feb 2002
  16. BorgBob
    BorgBob What's a Dremel?
    30 Mar 2002
    I love the serial ATA technology. It'll really clean up the cabling mess. Hopefully we'll be able to buy CDROMs with it too. If MSFT would just fix XP so you don't have to use a floppy for your RAID drivers during install, we could get rid of that buggy whip and truly be in the new Millenium.
  17. Digitalblueshift
    12 Feb 2002
    they might be thinking that the first people likley to buy a serial ATA board are the overclocers and techno-enthusiasts that have full towers and like to put the (ovbiously) hotter drives( because they will have to spin faster and generate more heat to keep up withthe transfer rates) in the top of their case above the PSU, in that way the Cables can be routed beside the infernal ATX power connector minimizing air resistance and tyding cable mess. Perhaps not, but who the hexk will turn down a board that is as backwards compatible as that one, I mean it even has legacy ports...
