Networks worried parent
Discussion in 'Tech Support' started by jonfrombelfast, 1 Jun 2010.
  1. jonfrombelfast
    jonfrombelfast What's a Dremel?
    27 Apr 2009
    Hi guy's. Need a bit of advice about laptop's and mobile phone's with Bluetooth. Is it possible to use a mobile phone to Hack into a kid's mobile phone with out the kid's knowing about it. In a class room enviroment using Bluetooth ?.
  2. varkanoid
    varkanoid Professional Dribbler
    18 May 2010
    simple answer make sure bluetooth is off.
  3. Neox010
    Neox010 EvE Addict
    24 Feb 2010
    Why does a kid need a phone during school?
  4. jonfrombelfast
    27 Apr 2009
    Most Kid's have mobile phones in school now.
  5. Gryphon
    Gryphon What's a Dremel?
    24 Apr 2009
    I haven't played around with bluetooth for a long time, but i know it used to be possible. i had an old PDA that would somehow bypass the user permissions, and would go straight into the file system of any device that had bluetooth on. With devices since then it has always asked the user if they want to allow that person permission, but i'm sure there will be a way to get around it with a bit of tinkering.
  6. Gareth24
    Gareth24 Folding = vdubs
    16 Jun 2009
    2 or 3 years ago when I was in school I know it was possible so I would assume that it still is but the easiest way to prevent it is to turn bluetooth off.
  7. montymole
    montymole Rigid Tubist
    24 May 2010
    Simple answer is yes it is very easy for any Bluetooth device to hacked, as a matter of fact our law enforcement and governments use such tools for snooping an other part of the covert big brother world
  8. saspro
    saspro IT monkey
    23 Apr 2009
    bluejacking is very easy to do. Great for free phonecalls if you're that way inclined (or dropping porn on to peoples phones).
    We used to log on to phones & add a phonebook entry called jesus loves you just for a laugh (when I was a kid)
  9. PureSilver
    PureSilver E-tailer Tailor
    16 Dec 2008
    Bluejacking's disturbingly easy. Never, ever leave it turned on.
