Windows Worrying Pc problem..
Discussion in 'Software' started by Crim, 30 Sep 2003.
  1. Crim
    Crim What's a Dremel?
    1 Jan 2003
    I keep having my hard drive filled up with something and I have no idea what. I get a low disk space warning so I cleared around 3gigs last night. I just got home from college and I have less than 200KB spare, this keeps happening. Is there any chance some hacker is using me as a storage for files? if so, how can I find out and stop it?
  2. Crim
    1 Jan 2003
    just checked again and I have 0kb space free, someone help!
  3. Supercool
    Supercool Gone.
    31 May 2003
    check for virus', spyware and trojans, and get a firewall if you don't already have one.
  4. Crim
    1 Jan 2003
    will do, but in the meantime is there anyway of monitoring when this data is being transfered and where it's being saved?
  5. Atomic
    Atomic Gerwaff
    6 May 2002
    you on XP?
  6. Crim
    1 Jan 2003
    yeah, I guess i could ctrl+alt+delete and look at network monitoring but that doesn't tell me where it's being stored :-\
  7. Atomic
    Atomic Gerwaff
    6 May 2002
  8. Crim
    1 Jan 2003
    i've already got the firewall turned on but I'll take a search for files now.
  9. white modder
    white modder What's a Dremel?
    19 Sep 2003
    use a virusscanner now
    and try eventviewer (win 2000 i do not know if you have it in XP)
  10. DeX
    DeX Mube Codder
    22 Jul 2002
    You can use Filemon on WinXP to monitor hard disk activities.
  11. scoob8000
    scoob8000 Wheres my plasma cutter?
    17 Feb 2002
  12. madhatter
    madhatter What's a Dremel?
    16 Sep 2003
    and / or check your virtual memory settings. windows might be using up most of your HDD with its pagefile.
