Build Advice Worth upgrading or past its prime?
Discussion in 'Hardware' started by LotusXyx, 16 Feb 2010.
  1. LotusXyx
    LotusXyx What's a Dremel?
    16 Feb 2010
    Hey all @ bit-tech,
    New user here, so salutations and all that first! Now, I'm a student with little to no cash, but I've inherited a (rather dated PC) from a family friend. I'm just curious to know if there were any suitable upgrades that I could do to it to make it run any better?
    I've never done any work to a PC previously, but I'm comfortable that I could handle a few simple upgrades. My main question is this: Is it worth upgrading any of this kit? Or would it be better to just lay it to rest? Anyways, here's the spec:
    Budget: approx £300-£400
    Main uses of intended build: Casual Gaming/Everyday use.
    Parts required: New GFX, Additional RAM, HDD Upgrade
    Previous build information (list details of parts):
    Mobo: ASROCK AM2NF6G-VSTA
    CPU: AMD Athlon 64 x2 3800+
    GFX: Radeon X1950 Pro
    RAM: Unsure on brand/model but only...1GB (333 MHz) :wallbash:
    HDD: 60GB (Desperate need of an upgrade)
    Monitor resolution: 1280 x 1024
    Storage requirements:
    Will you be overclocking: not considered it.
    Any motherboard requirements (no. of USB, Xfire/SLI, fan headers): NA
    Extra information about desired system: Like I said, I'm only really interested in a fairly cost-effective upgrade. If there isn't one to be had, I can live with it - the rig didn't cost me a penny as it is ^_^.
  2. okenobi
    okenobi What's a Dremel?
    3 Nov 2009
    Worth keeping, absolutely. Worth spending a fortune on - no.
    First thing - RAM. Ditch your 1gb and buy this:-
    http://www.crucial.com/uk/store/mpartspecs.aspx?mtbpoid=DD3210CCA5CA7304
    Or similar.
    Then get yourself a 1TB Samsung F3 and a Radeon 5770. Finally a copy of Windows 7 64bit and you'll be well under £400 and capable of doing any of the stuff you mentioned. In fact, at such a low res, you don't even need a 5770. You could probably get away with a 5670 or so, but depends on your budget.
  3. Abhorsen
    Abhorsen Minimodder
    10 Apr 2008
    Do you not feel he would benefit more from aiming towards the Bit-tech recommended budget build?
  4. sotu1
    sotu1 Ex-Modder
    24 Aug 2007
    Yeh upgrade to 2-4gb and you should notice a pretty substantial increase. What games do you play and what do you use the PC for?
  5. LotusXyx
    16 Feb 2010
    Thanks for the replies, guys.
    I'm glad to hear that it's not complete junk :). The resolution on the monitor does simplify things, which is good. Okenobi, thanks for the advice I'll definitely pick up that RAM, and I'll look into the GPU.
    Sotu, I mainly use it for CSS at the moment, but I'm a big fan of the Dawn of War franchise, and I'd like to be able to play DoW2 without it being terribly slow (as it is at the moment). Thanks again for the input, guys :).
    Concerning the GPU, would this be suitable:
    http://www.scan.co.uk/Products/512M...DDR5-GPU-775MHz-400-Cores-D-Sub-DL-DVI-I-HDMI
  6. Aterius Gmork
    Aterius Gmork smell the ashes
    25 Sep 2007
    I'd say sell it for a reasonable price, get a bit-tech recommended build (maybe slightly tweaked) and clock the nuts off of it. :) It's not a bad machine, and worth keeping (or selling to somebody) for daily work, but for gaming the new Intel CPUs will make a huge difference.
  7. LotusXyx
    16 Feb 2010
    @ Aterius, I've not the first clue how I'd go about selling it and I don't have the foggiest how much it would go for. On top of that, wouldn't it mean buying a new monitor as well?
  8. okenobi
    3 Nov 2009
    The HDD, GPU and Windows could all be carried over to a new build, as and when. Only the RAM will be lost in this machine. A £300-£400 budget build isn't going to bring that much value at this point. Later on when more money is available, a 5770, F3 and Windows 7 means than another £300-400 would give a nice core spec.
    That CPU will not be a total bust for gaming and will cope perfectly well with Windows and multi-tasking. It's simply a question of priorities. Go a bit at a time and you afford yourself more options.
  9. LotusXyx
    16 Feb 2010
    I've decided to go with a 500GB Spinpoint F3 instead of the 1TB. Reason being that I do also have a 1TB external HDD, so the additional space isn't entirely necessary. Plus, the 500GB HDD is £22 cheaper, so I'm happy with that.
    So far, here's what I'm considering:
    ATI Radeon 5670 : £66.16
    Samsung Spinpoint F3 500GB : £37.58
    4GB of RAM: £68.90
    Total: £172.64 (not including P&P) *Mistake Corrected*
    All from Scan.
    That gives me the option to put away the remaining money for a decent build after I finish uni.
    Any word on the GPU I picked out? Buy or avoid? (I know it's only pre-order at the mo, but it is dirt cheap).
  10. okenobi
    3 Nov 2009
    Bargain. Sorted.
    However, you'll want Win 7 x64 as well.
  11. Abhorsen
    Abhorsen Minimodder
    10 Apr 2008
    If you have 20+ postings on AVforums you get free delivery from Scan.
  12. LotusXyx
    16 Feb 2010
    Brilliant, that's good to hear. Any particular version of x64? Will Home do?
    Thanks for the tip, Abhorsen ;-)
  13. okenobi
    3 Nov 2009
    Home Premium will be fine for most needs. Pro's too expensive now anyway.
