Would a good sound card affect my podcast?
Discussion in 'Hardware' started by OneSeventeen, 6 Jul 2006.
  1. OneSeventeen
    OneSeventeen Oooh Shiny!
    3 Apr 2002
    I'm about to start a few podcasts, so I bought a $30 plantronics headset/mic set (I've heard they are good for starting cheap.) and I'm not too impressed with the volume of the sound. (The quality is decent for a PC mic though.)
    If I forked over the cash for a sound-blaster X-Fi Platinum, would I be able to record better? Or would I simply be able to play higher-quality surround in games? (I don't game anymore.)
    Should I just go cheap and stick with my nForce 2 chip until I can afford a proper mixer with phantom power and a decent mic?
  2. cpemma
    cpemma Ecky thump
    27 Nov 2001
    I doubt your soundcard, even onboard, is the weakest link in the chain... ;)
  3. olly_lewis
    olly_lewis What's a Dremel?
    19 May 2006
    Yer you're going to expect some trashy audio from equitment around that price, what brands are they BTW? If they are no name or just a PC shop boxed and bought them its not your soundcasd, its the mic....
    You should try out a few podcasts, get some feedback and then make the descision wether or not to purchase some high brow mics and headsets...
  4. hitman012
    hitman012 Minimodder
    6 May 2005
    I had a Logitech Gaming Headset a while back (before I broke it) and the microphone quality was extremely good - it was also fairly cheap. However, the earphone style might not be to your taste.
  5. Da Dego
    Da Dego Brett Thomas
    17 Aug 2004
    When Bindi and H and I do ours, I use a logitech behind-the-head gaming headset. It really works quite well, though it is a touch quiet. That's the worst I can say for it, though...the audio quality is none too bad, and I use on-board sound as well.
    Actually, the weakest link in our chain is a coin-flip between skype and Bindi's router.
  6. Adam-Mck
    Adam-Mck What's a Dremel?
    20 Jul 2005
    lmao sounds like bindi's got network issue's :p perhaps the people should help him out.
    for better sound recording would require a better mic compared to buying a new sound card. but if you the money i say buy the sound card as it will imporve game play feel in games
  7. Guest-16
    Guest-16 Guest
    If I could podcast from work, it would be fantastic, but I either share a net connection with 10 others who whore it for all its worth, or, do it from home on a flaky router.
    I use a £30 platronics headset with ac97 on my lappy. I was using my exitigy which DID make it better but Hiren is using that now.
    What's your podcast then??
  8. Hiren
    Hiren mind control Moderator
    15 May 2002
    £20 Plantronics headset with bindi's exitigy, get away from onboard would be my advice. (Not need to go ott) but any decent soundcard has to be better than onboard.
  9. Atomic
    Atomic Gerwaff
    6 May 2002
    I've heard nothing but good things about the MacMice MicFlex, lots of the Tech Podcasts use them.
  10. OneSeventeen
    3 Apr 2002
    I think I'll stick with onboard and get some feedback before making any investments, as olly mentioned.
    I still need to get at least 4 podcasts planned and 2 recorded before I get too ahead of myself anyway. (When I do get it done, it will be a Christian Geek podcast, since there aren't too many of those out atm.)
  11. Guest-16
    Guest-16 Guest
    Big market imo.
    Gl with that :)
