Electronics Would a 'touch lamp repair kit' make a servicable touch start thingy?
Discussion in 'Modding' started by disco volante, 21 Jul 2003.
  1. mod-ern man
    mod-ern man What's a Dremel?
    12 Nov 2002
    Cool, do I smell a how to coming up?
  2. viridius
    viridius What's a Dremel?
    7 Apr 2002
    Power can come from anywhere provided that it is 5 volts. The transistor can be any NPN small signal transistor such as a 2N2222 or a 2N3904. I help teach an electronics class at a museum. I asked for 5 of the QT113Hs to see if they would be good for general use. A few days later, 50 arrive.
  3. apoogod
    apoogod trix arent just for kids
    19 Jun 2002
    Sorry to quote myself but I need this answered if possable. Thanks
    Also do they make these for 12v...I didnt see any
  4. apoogod
    19 Jun 2002
    will this work for the electrode ....Transparent Electrical Film [​IMG]
  5. viridius
    7 Apr 2002
    No, you need to use 5 volts. You also need to connect a capacitor between pins 6 and 7 and tie pins 3 and 4 to ground or 5 volts depending on what functions you want. Where did you find that electrical film at?
  6. apoogod
    19 Jun 2002
  7. apoogod
    19 Jun 2002
    Ok how would I do this....where would I hook up the LED lines and is that ok where the resistor is? thanks
  8. malcs
    malcs oops! i put a hole in the ***** :(
    24 May 2003
    Where do you get that transparent electrical film!?!?!? it is just what i need for my clear traces!!!
  9. apoogod
    19 Jun 2002
  10. viridius
    7 Apr 2002
    Depends on what you want to do. A 0.01 capacitor goes between pins 6 and 7. The LEDs go between pins 2 and 8. If you want the sensor to turn the LEDs on when a finger is touching the plate, then tie pin 3 low and 4 high. If you want to have the LEDs turn on and stay on until the next time someone touches the plate, tin pins 3 and 4 low. Gain is determined by pin 5. Tie it low for low gain, high for high gain. (Low refers to ground/earth, high refers to +5 volts.)
  11. apoogod
    19 Jun 2002
    Ok you lost me, remember I have the brain of a 5yr old. Whats the .01 capacitor? I want the LEDs to be turned on and stay on till some1 touchs it again. Thats pretty much it. What do u mean by tie it to low or high? thanks sorry for the noobish questions.
  12. viridius
    7 Apr 2002
    The 0.01 microfarad (uF) capacitor goes between pins six and seven and determines sensitivity. If you put a 0.1 microfarad capacitor between pins six and seven, the switch would activate before you actually touched the pad. Upon further inspection, the clear conductive film may not work with this application, although you're welcome to try and post your findings. Pin 2 goes to LED + and earth/pin 8 goes to LED -. For your application, connect pins three and four to earth and connect pin five to +5 volts.
  13. apoogod
    19 Jun 2002
    tx viridius....the resistor is in the right place right? Also I take it soldering is the best solution for connecting the wires? Thanks
    oh ya...do they make 12v of these I didnt see any but I could of missed it?
  14. viridius
    7 Apr 2002
    The resistor is fine where it is. Position isn't an issue. I haven't seen 12 volt flavors of the QProx sensors, but you can just run them off of the 5 volt rail or buy a 7805 or some other voltage regulator IC.
  15. apoogod
    19 Jun 2002
    ya I have some 12 auto LED kits and I would love to hook those up to the touch switch. Thanks for the help
  16. apoogod
    19 Jun 2002
    Sorry just thought up another question....for the capacitor could I just use any type of metal? Would aluminum foil?
  17. viridius
    7 Apr 2002
    You can use aluminum foil or any sort of metal for the touch plate, if that's what you're asking. For the capacitor, you will have to use a premade one. They're cheap.
  18. apoogod
    19 Jun 2002
    got a link? :)
  19. viridius
    7 Apr 2002
    Digikey is good, but they have a $25 minimum order. Radioshack should have it for a buck or so.
  20. apoogod
    19 Jun 2002
    ok now I know I hate soldering.....theres got to be a easyer way
