Quick question guys... Would an ATi Radeon HD 4800 series card fit into this board?: http://www.newegg.com/Product/Product.aspx?Item=N82E16813128357 Thanks!.
Yup, should fit. PCI-E socket is correct, and there is nothing that blocks the card from fitting, that I see.
Well, so long as your case won't get in the way. The 4870 X2 is longer than ATX boards; it'll stick out over the edge by about two inches (5cm) or so. - Diosjenin -
