Build Advice Would like some opinion
Discussion in 'Hardware' started by onyxx419, 25 Aug 2009.
  1. onyxx419
    onyxx419 What's a Dremel?
    25 Aug 2009
    I am trying to build a budget gaming system, for about $850...
    This is what i have put together and would like some input on it from people who know more about it than I do...This will be my first build, and i wanna make sure everything i pick is good and compatible
    System:
    MSI 790FX-GD70 AM3 AMD 790FX ATX AMD Motherboard
    AMD Phenom II X4 965 Black Edition Deneb 3.4GHz Socket AM3 140W Quad-Core Processor Model HDZ965FBGIBOX
    XFX HD-487A-ZHFC Radeon HD 4870 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card
    Seagate Barracuda 7200.11 ST3160813AS 160GB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive
    I know i'm missing the RAM i haven't picked that out yet, but other than that is it all compatible and good working parts, and am i missing anything?
    any feedback would be greatly appriciated
    COOLER MASTER Centurion 5 CAC-T05-WW Black/Silver Aluminum Bezel, SECC Chassis ATX Mid Tower Computer Case
    AZZA Dynamo 850 850W ATX & EPS 12V 2.91 SLI Ready CrossFire Ready Power Supply
  2. Jambo72
    Jambo72 Playstuff.net
    15 May 2009
    Hey, I am from the UK so I don't work in $ so here goes. IMO if you extended your budget by $57 (I used Newegg.com) you could have yourself an i7 system that could easily be overclocked and can be upgraded in the future.
    Here is my calculations:
    AMD Phenom II X4 965 Black: $245
    MSI 790FX-GD70 AM3: $168
    = $413
    Intel I7 920: $280
    MSI EX58 PRO-E: $190
    = $470
    I would say thats not too bad. Will give you a lot more speed :rock:
    Then again its your hard earned cash and you can spend it however you want. That is just what I would do :D
  3. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    Could also drop the 965 for the 955 and save yourself 50 bucks and easily over clock it to the same 3.4ghz of the 965.
    A friend of mine has just swapped out his 955 for a 965 on the MSI GD70 and it isnt clocking as well as his 955 which he had stable up to 4ghz.
    I have the 955 and the GD70 and I wouldn't have bothered with the 965 if I was building now.
  4. onyxx419
    25 Aug 2009
    I know a lot more about AMD systems than i do about Intel, and i like the AMD quad core 3.4 thats the fastest AMD they make i was just concerned about everything being compatible and for that set up if the parts are good quality parts and not junk
  5. onyxx419
    25 Aug 2009
    the reason i am going with the 965 is because it is the fastest...i'm really new to computer building and i don;t know anything about OC so i wanted the fastest stock clock speed
  6. Slizza
    Slizza beautiful to demons
    23 Apr 2009
    You said you wanted it for gaming so you will have better games experiance if you dropped down the cost and opted for a Nvidia gtx260/275.
    You want those physx details in games ;)
    Here are some of the things you would be missing..
  7. onyxx419
    25 Aug 2009
    i did some research into the Radeon 4870 and its like one of the best GPU's Radeon makes outside of the 4870 x2 which is way out of my price range
  8. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    Oc-ing the 955 to the 965 is as simple as knocking the multiplier up by just 1 from 16x to 17x.
    Job done, fifty bucks saved.
    My 955 runs at 3.6ghz at stock everything with a multi of 18x and it will go up to 3.9ghz with out too much tweaking as well (I prefer not to run at that level though).
    Seriously save yourself $50 and we will get a 955 to run as a 965, don't let a very minor over clock put you off, plenty of help here for that.
  9. Elton
    23 Jan 2009
    HD4890....
    Oh and why does no one recommend the Q9550 + 750i/P45 combos? They're about $340 and damned good.
    Oh get the HIS HD4870 1GB ICE-Q, that thing is silent! Or get the Vapor-X.
  10. Jambo72
    15 May 2009
    I would suggest saving $45 and go for the cheaper http://www.newegg.com/Product/Product.aspx?Item=N82E16813130224. The board you selected is better because of its features and speed, however, this slight downgrade is still a great overclocker at a great price.
    You could then use that money where it matters more - The GPU. Upgrade to a 4890 or if your an nvidia fan the GTX 275 but on this occasion I think the 4890 is more in your price range for only $45 more on Newegg.
  11. onyxx419
    25 Aug 2009
    from what i;ve read about overclocking it has to do with messing with the power sent to the parts as well and i don;t want to mess around with that and fry my system
  12. Elton
    23 Jan 2009
    All you do is just bump the multiplier up by one in the BIOS. Imo the 965 is a waste. I still stand by my Q9550 suggestion.
  13. onyxx419
    25 Aug 2009
    aside from going with the slightly slower processor, is everything else decent, the GPU the Motherboard, power supply, case?
  14. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    No for that overclock you wont even need any extra volts.
    As I said mine does 3.6ghz with out changing anything else.
  15. Jambo72
    15 May 2009
  16. onyxx419
    25 Aug 2009
    i wanted a crossfire board cause i want to expand to duel GPU's
  17. Jambo72
    15 May 2009
    It is not as good as the 4890
  18. Jambo72
    15 May 2009
    Go with this board then!
  19. Elton
    23 Jan 2009
    The P45 board works with crossfire.
    Although you'll have to resort to getting a Q9550, which incidentally is almost as fast if not faster than the 965.
  20. onyxx419
    25 Aug 2009
    HIS H489F1GP Radeon HD 4890 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card so something like that would be a better card?
