would these work??
Discussion in 'Hardware' started by dead_man, 10 Nov 2004.
  1. dead_man
    dead_man Confucious say: WTF???
    4 May 2004
    corvette found some mad ass fans we wanna use on our comps, u think theyde work? look here
  2. riluve
    riluve What's a Dremel?
    29 Jun 2004
    Well, you have a few problems there . . . .
    here is a normal 120MM fan:
    12 VCD
    .40 amp
    4.8 watts
    Here is your fan:
    115vac
    50/60Hz
    40 watts
    Basically, its designed to plug into a wall. So, if you did that (plug it into the wall), then sure it would work fine. Otherwise, forget it.
  3. webbyman
    webbyman Hax.
    7 Oct 2004
    :rock: just plug it into the wall it would be super cooling :cooldude:
  4. scotty6435
    scotty6435 What's a Dremel?
    4 Sep 2004
    Careful with those fans because they are VERY powerful and could really FUBAR some of your kit (unsecured PCI cards, RAM etc). I'd love to give it a try but at like 65dB, I think that's a little too much for my ears to handle......and my neighbours :D
  5. dead_man
    4 May 2004
    corvettes PSU is alrady like more than 40db, and i dont care if it needs more power
  6. Kameleon
    Kameleon is watching you...
    29 Apr 2003
    Is Oz power 115V or 230V?
  7. JuMpErFLY
    JuMpErFLY Minimodder
    13 Mar 2003
    "only 60dB" lol
    If you want the peformance of the top one just get a delta 120mm, specs:
    - Speed - 4000RPM
    - Output - 190 CFM
    - Decibels - 59dBA
    - Dimensions - 120x120x38
  8. nick01
    nick01 What's a Dremel?
    6 Nov 2004
    Go for the EMB blower. You can build your system right into the exhaust duct. The CPU may still need some water cooling. They are tearing down a nuclear power plant in my area. I heard the pumps (5MW) and heat exchangers for fresh water intake are still available as surplus. :hehe:
  9. alastor
    alastor Minimodder
    6 Sep 2004
    ^lol^
    Although, I did seriously consider buying this for my really badly cooled rig...
  10. Froggy
    Froggy What's a Dremel?
    10 Jun 2003
    60db is nothing :)
  11. Who_me_33
    Who_me_33 What's a Dremel?
    26 Oct 2004
    Alastor, why not, it would move a lot of air, and if positioned right, you could remove almost all need for other case fans. The 240 volt fans, can you put a rheostat on them to slow them down. Im thinking of getting a 150 mm 240 volt fan for my case, because they dont sell 12v versions in nz
  12. alastor
    alastor Minimodder
    6 Sep 2004
    The main reason I didnt is because there isnt a hole big enough to fit it in...
    It'd have to go in the 5.5" drive bays, of which I only have 3 spare (crappy Tsunami ST64 case), which is only 140mm at most. I will be putting a 120mm in the space sometime, if I can find one quiet enough for a reasonable price...
    Problem being I need to try and find a decent powered 3 pin one, as i have no free drive bays (with the 120 in) to put a real fan controller :sigh:
  13. SpeedFreak
    SpeedFreak What's a Dremel?
    28 Mar 2003
    aussie power is the same as the UK, 220~240v @ 50hz
  14. Kameleon
    29 Apr 2003
    Thought so - that means plugging it into the wall probably wouldn't have the desired effect ;)
