Would this eliminate hd noise?
Discussion in 'Hardware' started by couzo, 8 Mar 2003.
  1. couzo
    couzo What's a Dremel?
    26 Apr 2002
    Just wondered if anyone had this and if it gets rid of hard drive noise?
  2. acrimonious
    acrimonious Custom User Title:
    8 Nov 2002
    I've just ordered one <cheeky grin>
  3. couzo
    26 Apr 2002
    cool they look great i just want it to be able to get rid of my hd noise to!!!!!!
  4. Moo
    Moo What's a Dremel?
    19 Aug 2002
    I am using a H/D enclosure from www.quietpc.co.uk .
    Works well. De-couples h/d from case reducing mechanical noise and acoustic damping inside reduces noise to less than my case fans.
    This model looks like it will transfer heat better with the alu casing. Very nice.
  5. couzo
    26 Apr 2002
    moo what case you got I got one with those plastic rails so don't know if it will get enough heat away from the hd so it may overheat in those what do you think?
  6. Fowler
    Fowler mmm Cosworth
    20 Nov 2002
    were can u get this in the uk? looks sweet as f00k!
    /me wants
  7. Cheese
    Cheese Doc
    6 Oct 2001
    scan sell them... http://web6.scan.co.uk/Products/Info.asp?WPID=21797
    I doubt they'll help much with noise, they're supposed to keep drives cool and make them easily interchangable. Pretty sure it had fans and will actually increase the noise of most systems.
    Rob.
  8. :: Phat ::
    :: Phat :: Oooh shakalaka!
    7 Jun 2002
    Icy Dock Mobile Rack 122AKGF + LCD Control ATA100/133 Aluminum + Fan
    ;) which means it'll be a whining 40mm version... :sigh:
  9. Moo
    19 Aug 2002
    My case has metal drive supports which get warm where my drive holder is bolted on. I mounted a quiet 40mm fan to blow air over the cooling fins and now its cooled down.
    I had a look at http://www.cremax.com.tw/mb122-ide.htm for some more info. Your design does have a small fan built in, and the aluminium construction should radiate heat away, hopefully it will be cooler than it is now, you can always 7v the fan.
    Getting back you your original question, the design doesn't say it is intended to quieten the hard drive, but I imagine it will help.
  10. Fowler
    Fowler mmm Cosworth
    20 Nov 2002
    im guessing these take up a 5" drive bay yeah?
    surely they dont fit in a floppy drive?
    :worried:
  11. Fowler
    Fowler mmm Cosworth
    20 Nov 2002
    URGENT:
    Can someone point out a review on this for me?
    I need to know if it will be ok in my antec with the door closed! Not sure if it extrudes from the drive bay too much or not?
    :rolleyes:
    EDIT:
    Excuse the above,
    http://www.modthebox.com/review43_2.html
    ^ A decent review, take a good look anyone whos interested! :D !
  12. couzo
    26 Apr 2002
    it will be fine wit hthe door closed as there is easily enough room for it
