Electronics Would this work?
Discussion in 'Modding' started by motas, 6 Jan 2010.
  1. motas
    motas What's a Dremel?
    7 Dec 2009
    I am getting a logitech g27 soon and I want a proper handbrake for it. I was thinking of having a bar on a hinge and putting a button above it so when you pull it up it hits the button. I could rewire one of the programable buttons on the gear box and solder it to the button. Also I could attach a spring to it to make it feel more real. Any thoughts?
  2. ChromeX
    ChromeX Minimodder
    12 Aug 2004
    Yeah I dont see any reason why it wouldnt work, though it would only apply the handbreak when the button was fully pressed. Having never driven car I wouldnt know how a handbreak feels when used.
  3. Prometheus
    Prometheus Minimodder
    26 Jun 2004
    I would go down a scrappy and take a real hand brake lever out of a car or look on ebay, has a pre mounted switch for the hand brake warning light that you can use then too, i'm sure you can disable the ratchet mechanism on them fairly easily and most of them just bolt into the car and come out in one complete unit.
  4. motas
    7 Dec 2009
    That's a good idea and I think we have a crunche car in our shed. Then it would feel very realistic. Does the stiffness come from the handbrake or from the car because I might need to put springs in it.
  5. grritsshawn
    grritsshawn I'm not insane I'm a modder
    20 Apr 2009
    logitech g27 is a beauty.... if i don't recall i remember about 2-3 months ago seeing a handbrake for a gaming wheel when i was helping my buddy build his flight sim and racing housing(not sure what to call it)
  6. motas
    7 Dec 2009
    Do you know what it was called or what brand it was?
  7. grritsshawn
    20 Apr 2009
    idk r u in the uk or us i will try to find it for you
  8. dark_avenger
    dark_avenger Minimodder
    9 Jul 2008
    tension on the handbrake comes from the brake coming on.
    you would need a spring to simulate it.
  9. motas
    7 Dec 2009
    Thanks I'm actually in australia but other countries are fine. Thats annoying about the springs.
  10. grritsshawn
    20 Apr 2009
    this might be hard i will try to find it tho
  11. motas
    7 Dec 2009
    tyvm
