Would this work?
Discussion in 'Hardware' started by Froggy, 25 Jul 2004.
  1. Froggy
    Froggy What's a Dremel?
    10 Jun 2003
    I was thinking about getting a new CPU for my board, the Gigabyte GA-8INXP. Currently i got a 2.8 Northwood 533 that overclocked to 3.2ghz. I Was thinking of going with the Northwood 800mhz. I know my board dosent souport the 800mhz what im thinking was, if i get lets say a 3.2ghz 800, the system will underclock it till the fsb is back at 533. If im not mistaken the speed will now be 2.1ghz, then i would Overclock it back till it got to 3.2ghz. would this work? has anyone tryed it?
  2. Anator
    Anator What's a Dremel?
    26 Feb 2004
    As long as the socket is the same which i assume it is, then the mobo will just set the fsb down to what it can cope with - i tried this years ago on an old system and it worked, should work with this too.
  3. Froggy
    10 Jun 2003
    ok thats good to hear. My board and the the processor im looking at getting are both Socket 478
  4. Anator
    26 Feb 2004
    Should work as long as the 800 can function correctly at 533, might be worth getting someone to test it before you buy
  5. Froggy
    10 Jun 2003
    It wouldnt be running at 533 once i change the FSB to get it back at 800. From there i can probably overclock it further.
  6. Anator
    26 Feb 2004
    Yeh but in order to change the FSB you need it to function at 533 initially :p
  7. Froggy
    10 Jun 2003
    lol true. i was looking on newegg and i saw the 2.4ghz p4 cheap. everyone in the reviews are bragging about how it easly overclocked to 3.2ghz. me is thinking about getting it.
  8. Mister_Tad
    27 Dec 2002
    it is pretty likely that if your board doesnt support 800MHz fsb it will crap out well before the 800fsb mark when "overclocking" the cpu back to stock, let alone allow for even further overclocking
  9. Froggy
    10 Jun 2003
    just the kinda reply i was looking for. this did sound to easy. i am still considering dooing it.
