Electronics wow need help wiring the 2x16 LCD
Discussion in 'Modding' started by Bboy_Jon, 30 Dec 2004.
  1. Kerri Ann
    Kerri Ann What's a Dremel?
    12 Oct 2004
    yep. the other two wires that are hooked up to the pot just set the range (high and low) for the pot. ground is the low, and 5V is the high. the middle pin is called the "wiper" pin, and when you turn the knob on the pot, it does like a windshield wiper, and moves in an arc from one side to the other.
    i think it should be ok to leave the pot with the two wires attached, but i would remove the pot altogether if that's possible, just to be sure.
  2. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    but everything should still work with the pot hooked up shouldnt it?
    but arent the 5v and the gnd wires connected then?
  3. Kerri Ann
    12 Oct 2004
    no, they are not connected. they simply set the range. either way, just to be on the safe side, disconnect the pot completely.
  4. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    k so i just have everything connected, except its not on the legs of the pot?
  5. Kerri Ann
    12 Oct 2004
    yes. just leave everything as you had it, remove the pot, then tie pin 3's wire to pin 1.
  6. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    kk I HOPE IT WORKS!!
    i just dunno if i can do it before the weekend
    btw, in order for the row of blocks to show up, do i need to have software installed and be trying to send a signal?
  7. Kerri Ann
    12 Oct 2004
    nope. don't freak out though if you don't see the blocks. i have put together about 25-30 of these things, and i have had a few that didn't ever show the blocks at all- but they worked perfectly fine.
  8. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    kk ill try it today i hope
  9. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    dammit still doesnt work, I DONT GET IT!!!!!!!!! WTF :wallbash:
    god dangit, im thinking about just buying a serial or usb lcd, but then id be mad because i bought a parallel pci card just for this dam lcd
  10. Kerri Ann
    12 Oct 2004
    no no! don't give up! you will get it to work. maybe some pictures would help a bit- if you have a digital camera, snap some pix and post them here, and maybe i can help you more.
    snap some good close ups of the contacts on the lcd, and be sure to also take pix of where the through hole contact is missing. (pin 4?)
    just don't give up yet.
  11. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    theres nothing i can do, my camera cant take decent quality up close clear shots
    its either the contact from pin 4, or my lcd is F**ked nothing i can do about it
