I have a MSI 52-m cd writter, and have installed it correctly and with nero that came with it, thing is it only copys from another cd, and it just crash's if i try to do a data cd.... why is this? thanks.
update all your drivers (nero and cdwriter if poss.), i had a similar problem. otherwise, good luck, cos thats all i can suggest.
different promlem I have a different problem, i have been testting the writter and it works fine if i set it to master and put it on the end of the ide cable, but if i put it on the other connection on the ide cable or with another cd-rom on the cable it doesn't work. does any one know why!!!!
tryed that, it doesn't work. it only works if the cd-writter is set to master and there no other cd-roms attached for some reason.
I have tested the writter in another pc, and it works fine, it works fine in mine if i disconnect my dvd-drive from the ide cable. which is strange, why is this is there a setting that as changed in the pc some were.
I tryed a new ide cable and it made no difference. In the end i disconnected the dvd drive and connected it on the ide with the hard-drive, and now the writter is workking fine. bit anoying to say the least.
