Windows WTD: Recommend me a FTP program
Discussion in 'Software' started by monkeyville, 5 Sep 2005.
  1. monkeyville
    monkeyville Evilish Monkey ++;
    3 Aug 2003
    I've used LeechFTP for years now and i'm bored of it. Also i get the feeling there's probably better software out there so recommend me something better. Also i hate how it times out so damn fast.
    All i ask is that its free and wont timeout every 300seconds like leech does.
  2. hitman012
    hitman012 Minimodder
    6 May 2005
    SmartFTP is quite a good program that I use a lot. If you don't want it to time out, it can be programmed to send a command automatically in the preferences. I have just set it to execute "LIST -aL" every hundred seconds or so.
  3. TekMonkey
    TekMonkey I enjoy cheese.
    6 Dec 2002
    I use SmartFTP as well. It's a pretty simple interface, it makes it easy to upload files very quickly.
  4. Dinh
    Dinh What's a Dremel?
    27 Jun 2004
    FileZilla is very good too. Plus, its free and open source. :)
  5. Skylined
    Skylined Minimodder
    3 May 2003
    One more vote to FileZilla. ;)
  6. BBurger
    BBurger What's a Dremel?
    7 Apr 2005
    Another vote for FileZilla.
    I just wish they'd hurry up that Linux port they were talking about, because the default graphical FTP app in Ubuntu - gFTP - is garbage, and FTP-via-file-manager has a couple of details lacking.
    FileZilla is one of only a few things I miss from Windows, actually...
  7. Hiren
    Hiren mind control Moderator
    15 May 2002
    Also use FileZilla here.
  8. Hex
    Hex Paul?! Super Moderator
    11 Jan 2002
    I use both SmartFTP (free for personal use) & FileZilla here.
  9. monkeyville
    3 Aug 2003
    Cheers for the suggestions guys and gals
    Could i just ask why you use 2 programs that essentially do the same thing? What does one do that the other doesn't?
  10. Hamish
    Hamish What's a Dremel?
    25 Nov 2002
    filezilla does sftp
    i use smartftp for the odd occasion i use ftp and winscp for sftp/scp (because whilst filezilla supports sftp it doesnt support using keys)
  11. Hex
    11 Jan 2002
    I have more than 1 machine, and I test a lot of software so just ended up sticking to those 2 programs on the machines they're on. I mainly use FileZilla for the local ftp & SmartFTP is on the machines that grab stuff from outside. No reason for it, it just ended up that way. If I ever go and rebuild all the machines I'll probably just use FileZilla, there's nothing wrong with SmartFTP though, it has some nice features.
  12. kenco_uk
    28 Nov 2003
    FTP Navigator here. Free to use, works really well.
  13. Gipo
    Gipo What's a Dremel?
    20 Sep 2004
    I use flashFXP myself
  14. mushky
    mushky gimme snails
    24 Mar 2003
    WSFTP LE here.
    It's free and does a reasonable job. The only thing that does bug me about it is if I want to send loads of little files, it can take ages. I might try out some of the other suggestions on this thread to see if they are any better.
    Sometimes I just use IE if I want to send a couple of files accross. Very easy to do. ftp://[username]:[password]@ftpserver.com then just drag and drop from windows :)
  15. cpemma
    cpemma Ecky thump
    27 Nov 2001
    I use Terrapin cos it's very easy to use for transferring a few files up to the websites (and besides I paid a modest sum for it in a Freeserve deal years ago and want my money's-worth :eyebrow: ) but I'm currently trying CuteFTP and others because Terrapin doesn't show how much webspace I've filled. I'll probably end up with Terrapin and A N Other on the box. :D
  16. Angus
    Angus What's a Dremel?
    21 Mar 2005
    I use FileZilla, because SmartFTP kept messing me about, but then I found it it was my hosting that was screwing around, and just didn't go back :)
  17. RTT
    RTT #parp
    12 Mar 2001
    SmartFTP :)
  18. edz
    edz What's a Dremel?
    18 Aug 2003
    flashfxp is nice, but it's not free
