Development "www" or not?
Discussion in 'Software' started by sam.g.taylor, 4 Apr 2008.
WWW?
  1. Yeah, sure, it's popular and looks better
    18 vote(s)
    47.4%
  2. Nah, it's unneccesary and symmetry be damned
    20 vote(s)
    52.6%
  1. sam.g.taylor
    sam.g.taylor Apparently I'm Greg Kinnear
    15 Aug 2006
    I just set up a new Drupal installation for a site I'm working on and I have to choose to have a "www" in the URL or not.
    For now I've decided against it, because it will keep things simple for me when I implement subdomains.
    However, I have heard some things both for and against the use of "www" in regards to SEO. Also, there's the question of aesthetics and whether it's more popular for users to type it in or not (as I have found, my tech-savvy friends generally don't type it while it's more common among those who are less technically inclined).
    What do you think? Is "www" dead?
  2. notatoad
    notatoad pretty fing wonderful
    25 Jun 2004
    doesn't really matter, imho. www.site.com and site.com should both lead to the same place anyways, unless you want to piss off your customers/users
  3. Cthippo
    Cthippo Can't mod my way out of a paper bag
    7 Aug 2005
    Voted yes, but I agree with supertoad, it needs to work either way.
    What drives me crazy are the people who will get to a site by going to google and typing the URL of the site into the search box :wallbash:
  4. Delphium
    Delphium Eyefinity enabled
    18 Mar 2007
    Personally to me it matters not, however if I was for example to give an address of site.com to my father or sister, they would instinctively put www. before it, there has been a number of times that either of them had an address as such and complaind it not to work because the server did not support www. , so I guess it depends on what your intended audience is.
  5. badders
    badders Neuken in de Keuken
    4 Dec 2007
    It actually really annoys me when sites don't have their DNS records set up correctly, so you MUST HAVE www before them.
    For instance, empirecinemas.co.uk doesn't work, but www.empirecinemas.co.uk does.
    If there were any other cinemas in the area, I'd go there just because of that.
  6. Hamish
    Hamish What's a Dremel?
    25 Nov 2002
    you should have www in front and that should be your site domain dns name but site.tld should work too
    best thing is to put a redirect on site.tld to www.site.tld imo, but thats often hassle
  7. RTT
    RTT #parp
    12 Mar 2001
    You should be available on both, but for SEO use only one. I.e., bit-tech.net/hardware will forward you to www.bit-tech.net/hardware and send a "301: permanently moved" header.
  8. vaderag
    vaderag I know what a Dremel is...
    19 Jul 2007
    RTT - you're bang on in my opinion. Just been talking about this with a mate of mine who i'm setting up a site with, so quite good timing for this debate :)
  9. liquid_gen
    liquid_gen What's a Dremel?
    12 Feb 2006
    Aaaaargh :wallbash: I f***ing hate that! Every friend i've seen recently browsing the internet does that. I seriously feel like hitting them when they do that.
    Also, i hate that none of them seem to know how to use a search engine properly. It wouldn't bother as much because I can't expect every one to know how search engines work but some things just seem like common sense to me: like don't bother typing in words like "the".
  10. vaderag
    19 Jul 2007
    We've got a bit of an issue with our domain... when we set it to have the www (with dreamhost), we end up in an infinate loop so the page wont load. Anyone able to help us with this?
  11. cpemma
    cpemma Ecky thump
    27 Nov 2001
    www.mydomain.com is more "obvious" in advertising or letterhead, especially if it's aimed at the general public. Don't confuse them. :nono:
  12. RickDawson
    RickDawson Minimodder
    29 Mar 2006
    have the domain on the server, with nothing infront of it and add an "A" record for it (www) on the server.
    www. is a subdomain just like any other subdomain.
    an example from the BBC
    they were saying bbc.co.uk (without the www.) on some of their programmes,
    They had it so it would only load with the www. in front of it.
    Eventually they sorted it to load either way.
  13. Millusdk
    Millusdk What's a Dremel?
    27 Jan 2008
    Somebody must have banged his or her head against the wall because of this :wallbash: That is just plain stupid
  14. sam.g.taylor
    15 Aug 2006
    Yeah, I'm planning to have any requests to www.flaglerama.net redirect to flaglerama.net (that's the site, btw). Since there will be a lot of subdomains off of this main domain I think it's easier just to omit the www in the first place. An address like "www.beta.flaglerama.net" is just too damn confusing.
    But of course I'll redirect and advertise appropriately - pulling a stunt like BBC's is just... dumb.
  15. Firehed
    15 Feb 2004
    Yes, but by forwarding (two lines in .htaccess if it matters to you). Having both exist in parallel rather than having one forward to the other is terrible for SEO. Just pick one and go with it, but don't let both exist.
    I like it for the way it looks and use it across all my sites. It also, in theory, adds some sort of 'definition' to what part of the site you're accessing. But that really only matters if you were to do ftp.yoursite.com, etc for all the different protocols. I just stick with folders, since forums (etc) are part of "www" imo. But it really doesn't matter, just be consistent.
  16. Ramble
    Ramble Ginger Nut
    5 Dec 2005
    If it doesn't load with both www.mysite.com or mysite.com then I simply wouldn't visit it. It's insanely annoying having to put the extra www in when you don't usually type it.
  17. DaveVader
    DaveVader Fast Action Response Team
    10 Aug 2007
    The website we use for our Bio A level has to have www. in front of it.
    I hate the site anyway so I dont use it.
  18. ChaosDefinesOrder
    ChaosDefinesOrder Vapourmodder
    6 Feb 2008
    just a little point here, this forum thread has highlighted a possible problem with omitting the www. in that when you type a website address into any page as-is or into word processing programs, then site.com will be seen as text only, however www.site.com will turn into a hyperlink automatically. If you intend to quote your website in forums and emails etc, then you'll have to use http://site.com or use html tags to get a clickable hyperlink. Otherwise people will have to type it manually or copy and paste the link into address bar.
    yes, I know it's a picky and slightly lazy point, but it's something to point out...
    personally, I like Opera's way of offering "go to URL" in the right click menu if you highlight text! I'm also a fan of not having to type out the www. every sodding time I want to load a website!
  19. Snaek
    Snaek What's a Dremel?
    10 Jan 2004
    Usually when entering URLs into the address bar I just type the name and press ctrl+enter, for example I type google and press ctrl+enter to turn it into http://www.google.com/.
  20. sam.g.taylor
    15 Aug 2006
    Interestingly enough, I just got my "Happy Birthday" email from Bit-Tech (yay! and thank you) and the link was http://bit-tech.net, without the www. :eyebrow:
