Scratch Build – In Progress WyWyWyWy's NUC Cooling Experiments & (Eventually) Custom Enclosure
Discussion in 'Project Logs' started by wywywywy, 5 Sep 2016.
  1. wywywywy
    wywywywy Minimodder
    26 Sep 2002
    This my attempt of experiments on cooling a very hot NUC, and then build a custom enclosure for it afterwards with whatever cooling method I end up using.
    This is going to be a long project with a number of things to try, and most likely a number of failures too.
    So the back story - I currently have a work-from-home SFF machine, with a Silverstone SG13 (11 litres), i7-3770, 16GB, two SSDs, Intel PCIe network card. When I built this machine I wanted it to be as small and quiet as possible but at the time NUCs were slow and only supported one drive. I didn't (still don't) need a discrete GPU obviously.
    This image below is my gaming PC (white SG13) on top of the work PC (black SG13).
    Then it changed when Gigabyte released NUCs with desktop-class CPUs, with one mSATA + one 2.5" SATA. It doesn't have an Intel NIC but it's only 0.8 litres!!
    And as if by luck I managed to find a used one for a very reasonable price, because it had a broken case.
    This is a Gigabyte Brix Pro with an Intel Core i7-4770R (very similar to 4770), 16GB DDR3L, and two SSDs.
    I don't care about the broken case because I knew I'm going to gut it, after reading the complaints of REALLY BAD thermal throttling. The CPU has a 65W TDP and the chipset has about 4W, and this is the cooler that Gigabyte attempted to cool it with...
    Well yea it throttles even worse than the reviews say. In Prime95 it gets to 100C after seconds, and with the fan sounding like a hair dryer. Coolers like this are really only suitable for 35W TDP CPUs.
    To simplify the testing, I'm going to use the idle BIOS temp with the fan on 100% as a reference to try different cooling solutions.
    The stock solution is around 60C in BIOS.
    The first step is to replace the TIM. The factory one is actually applied pretty well. Anyway I used the Noctua TIM and gave it a go. The chipset used a stock thermal pad.
    Experiment #1 - Replace TIM. Result - ~60C. No difference.
    Oh well... Anyway to address the noise issue, the obvious solution is to replace the fan. But it uses a non-standard plug, so I had to cut off the connector of the original blower and do a bit of soldering to make an adapter.
    And then I have two fans to try. The first one is a Noctua NF-A9x14 low profile fan that came with the NH-L9x65 cooler. There's no mounting holes so for the experiment I just used rubber bands to strap it on.
    Experiment #2 - Stock heatsink + NF-A9x14. Result - ~56C. Cooler and quieter but not that much better really.
    The second fan is a full size Noctua NF-A9.
    Experiment #3 - Stock heatsink + NF-A9. Result - ~56C. Not sure why it's pretty much the same (both noise and temp) as the slim fan? I was expecting better.
    The very slim copper heatsink is probably the limiting factor, so it needs to go.
    But before I mount another heatsink on, the soldered nuts (to secure the stock heatsink) needed to be grind off a bit with a Dremel first because they were taller than the CPU by about 0.5 to 1mm.
    To balance the pressure of the heatsink off the bare chips, I used 1mm thick neoprene to make a gasket for them. Unfortunately they didn't work well... :( They were a bit too tall so it needed a lot of pressure on the heatsink to make good contact with the chips. I think 0.5mm neoprene would have been perfect but I cannot find any at all. They were promptly removed.
    To be continued.
  2. wywywywy
    wywywywy Minimodder
    26 Sep 2002
    Okay so the neoprene idea didn't work last time, and this time I'm trying a different material... And I'm not sure why didn't I think of it in the first place and went around messing with neoprene sheets.
    This is silicon thermal pad in the right thickness (0.5mm) that is more widely available and cheaper than neoprene, and it may (but probably not) help with heat dissipation too.
    And yes it works quite well. Recommended for people mounting things on bare die. I may even go and do it to my water cooled GPU in another PC actually.
    So I've been quiet since the last update, because I've been trying to think of EASY ways to mount various cooling devices and the bracket making will take me forever. So in the end I bought this to help!
    The first "product" from this 3D printer is a set of brackets for a Noctua NH-L9x65 heatsink. The print quality is not brilliant because the printer is not properly calibrated yet (because I got too excited). And the material is PLA not ABS so it's not 100% suitable long term as it can potential soften during high heat, but for testing it doesn't really matter much.
    Since there isn't enough space for a proper heatsink, the north bridge at the moment is only cooled by a roughened up small aluminium plate (10x25x2mm), which again is enough for testing with it only dissipating 4W of heat, but for long term use it should be a bigger copper plate (25x25x3mm) really.
    Unfortunately the original slim 92mm fan is being used by another project, so it is using a full fat Noctua NF-A9 for this experiment.
    And here is how it looks. A bit comical really like a big head on a small child.
    Experiment #4 - Noctua NH-L9x65 + NF-A9. Result - ~46C. That's pretty good actually. If I didn't have more cooling devices to try, I'd probably have called it a day and settle with this.
    Going to produce more brackets to try different things next time!
  3. Yadda
    Yadda Minimodder
    25 Jul 2003
    Nice work. I'm curious to see what other "cooling devices" you plan on trying.
    I had to laugh at "like a big head on a small child". At least it's not ginger. :D
  4. wywywywy
    wywywywy Minimodder
    26 Sep 2002
    Here comes a new challenger.
    This is an Asetek 545LC AIO water cooler with a 92mm radiator. This was my original BIG IDEA(tm) when I first got the NUC, because the dimensions are similar to the NUC footprint (102x102mm), which will make enclosure building easy, compact, and tidy.
    It's a very unusual AIO in that the radiator is only 92mm, while everything else on the market is at very least 120mm. This 92mm one is popular with the Shuttle community being the only AIO that will fit. It's very difficult to find - only sold by Asetek themselves through Ebay, and only in the US, with a high-ish price tag. Rarer than a hen's teeth.
    Unfortunately I haven't had time to 3D model a bracket for it yet, and I happened to have some scrap aluminium bars around that fit quite well, so for this experiment I'm going to easy route. But if one day it turns into a permanent solution then a proper bracket will be made.
    Again the north bridge is only cooled by a small aluminium plate for now. I'm reusing the Noctua NF-A9 fan for consistency.
    Experiment #5 - Asetek 545LC 92mm AIO + NF-A9. Result - ~39C. Wow that's nice! I don't get how it can have such a big difference to the NH-L9x65 considering the same fan is used? But I'm not complaining! Maybe it just mounts better.
    However, playing around with it for a bit, I'm sad to say this solution is a no-go. The tubing is just too long and WAAAAAAAY too stiff. There's no chance of making a proper enclosure for it. :(
    There's the possibility of replacing the tubes of course, but the difficulty and potential problems are probably not worth it... Unless anyone can suggest an easy way?
  5. wywywywy
    wywywywy Minimodder
    26 Sep 2002
    So things were a bit of a roller coaster for me, and I'm spending too much time on the 3D printer (also building a new one from scratch...), hence the lack of update.
    So firstly, while filling I actually spilled water onto the NUC! I almost cried but then I remembered it wasn't powered on. So I made a sealed rice box with 4 people's worth of dry rice, and put the whole thing in it. My family didn't get to have dinner that evening.
    After a couple of weeks I took the thing out, hoping that it's totally dried, and plugged it in and pressed the button... NOTHING. Pressed a few more times, still nothing. Folks, you should see my face when I killed a few hundred pounds worth of machine due to my own clumsiness. So I put it back to the rice box and cried in a corner.
    Another couple of weeks went by I was deciding whether to throw it all away, but before that I gave it one more go. And... still nothing. But then a light bulb appeared over my head and maybe, just maybe, the button cell battery is dead (which partly because I was replacing the battery on my car's remote key minutes prior). So I swapped it with a new one, and VIOLA! IT'S ALIVE! Then I quickly finished the rice in the rice box.
    This is an Alphacool Esiberg 240 expandable AIO with a 240x30mm full copper radiator, two 1600rpm 120mm fans, and a pump-block-res in one unit. It's an overkill for the NUC for sure but for curiosity sake I had to know how it performs.
    It's using the crappy brackets from last time to mount the AIO, which is actually really secure.
    [​IMG] [​IMG]
    Apologies for crappy pics. My office is a total mess at the moment. But I hope you get the idea.
    Again the north bridge was only cooled by a small aluminium plate for now. I can't use the Noctua NF-A9 fan on it obviously so I'm using the original Alphacool fans.
    Experiment #6 - Alphacool Eisberg 240 AIO. Result - ~35C. Ok this fits with expectation, considering its size. So no surprises here.
    This is of course not a practical end solution, but who needs practicality anyway? Next time we need to go BIGGER.
  6. wywywywy
    wywywywy Minimodder
    26 Sep 2002
    This project is not dead. I'm still working on it.
    This below is what I was going to put on it to experiment. It's a full EK kit with a EK Supremacy EVO block, PE 240 radiator, and a D5 pump with res.
    Unfortunately I couldn't get the water block to fit :( The base of the block is just too fat for the components on the PCB.
    So moving on.
    This is what I tried next - the previously used Alphacool Eisberg pump/block with a Magicool 92mm copper radiator, with the same Noctua NF-A9 fan from before for consistency.
    I believe I bought the very last Magicool 92mm radiator in the UK! And the reason I bought it is that it's a whole lot cheaper than (less than half) the similar-sized Alphacool and Black Ice Nemesis. The construction quality is pretty nice too.
    The fittings are EK and the soft tubes are 16 OD 10 ID.
    The pump/block unit is now held down with a bracket I designed in Fusion 360 and printed out in PETG. I went through numerous iterations to get the fitment and strength right. The pic above is one of the earlier iteration, and the pic below is the final version.
    I used some scrap 3D printed plastic as "legs" for now.
    Experiment #7 - Alphacool Eisberg + Magicool 92mm Radiator + NF-A9. Result - ~38C. Pretty much as expected. About the same as but slightly better than the Asetek 545LC.
    So this cooling solution is what I've settled with and next I'm going to attempt to build a case for it by 3D printing.
  7. wywywywy
    wywywywy Minimodder
    26 Sep 2002
    The first step to building the case is to make a skeleton.
    This "frame" supports the PCB and then attaches to the water block mount, as well as allows fitting a 2.5" drive.
    Structurally there are 4 long M3 screws, one at each corner, to join everything together.
    It's again modelled in Fusion 360.
    It's then printed out, again in PETG. This particular filament is the FormFutura HDglass, in smokey black. Pretty nice filament to work with and the semi-transparancy looks pretty cool, although it's quite a bit more expensive than others
    And this is the outcome. The dead 2.5" drive is just a placeholder until the final SSD goes into place.
    I also soldered a nice vandal switch button on with LED. The soldering isn't very strong because the contact points are small, so I may need to put some hot glue on :(
  8. wywywywy
    wywywywy Minimodder
    26 Sep 2002
    The next step is the "base".
    The design again is done in Fusion 360. The four main long screws that goes through the skeleton are used to secure to the base.
    The design itself is rather simple. Definitely more function than form. Mainly because my creativity isn't with me right now.
    The pattern on the left/right sides is called a "Voronoi Diagram". I decided to use this pattern because it looks interesting and is different to the usual round or honeycomb holes that you see all the time.
    It now finally resembles a case.
    It can also be used as is, and I have actually started using this computer now after nearly a year of buying the NUC!
    The next step is the front cover.
    However it is not without problems!!! Firstly the BIOS fan control has a mind of its own and does not work properly, and SpeedFan can't control this particular board, so the fan has to be ran at full speed right now... Secondly the board is quite hot to touch, even though the CPU and the chipset are both sub 40C, so I'm guessing it's from the VRM whose input is 19V. And lastly the NUC shut itself down once while I was using it, like the power cut out... I don't know what it means and I hope it's just a one off...
  9. Cheapskate
    13 May 2007
    I suspect you need to cool that 2nd chipset. Fun stuff, though.
  10. wywywywy
    wywywywy Minimodder
    26 Sep 2002
    The southbridge? It's fine it's only like 3W TDP and it has a copper sink on it :)
    The VRMs were hot though, and I have since put small aluminium sinks on them and they're now much cooler!
  11. Cheapskate
    13 May 2007
    I was hoping the escalation of cooling would progress to a monoblock. ;)
  12. wywywywy
    wywywywy Minimodder
    26 Sep 2002
    Never say never though... I'm researching easy ways to make water blocks!
    Also I haven't figured out a good way to put/hide an Alphacool DC-LT pump yet.
    I may revisit this later this year when I've completed another project (Ryzen water cooled Ncase M1).
  13. wywywywy
    wywywywy Minimodder
    26 Sep 2002
    So I "designed" a cover for the NUC in Fusion 360. It really is nothing more than a cover with holes for USB etc.
    It looked pretty bland and uninteresting to be honest. So I decided to give it some graphics, and sticker-bombed it.
    I quite like how it turned out. The good thing is that if I change my mind, I can easily remove them all and start again.
    The stickers could do with flattening a bit though :D
  14. Mojo
    Mojo Multimodder
    18 Nov 2011
    Really like that!! :D
  15. Guest-23315
    Guest-23315 Guest
    Yeah, but you of all people would say that...
  16. wywywywy
    wywywywy Minimodder
    26 Sep 2002
    One thing I found is that the printed bracket to hold heatsink down is a bit inconsistent. To solve this issue, I had the bracket laser cut in mild steel. It's then spray painted with grey primer and matt black for protection. The nuts to hold it down is now Nyloc so they won't lose tension unexpectedly.
    At the same time I also opened everything up to clean & flush all the bits because there was some plasticiser in the old tubing. The chrome elbows were replaced with black ones - just look a bit better really. The soldering on the LED & power switch was also reworked to make them stronger.
    As for the cover, I was given the idea of using a transparent vinyl film over it so it stays nice and flat :) Which is just what I did, with a matt texture one to avoid the glossy look!
    There's some air bubbles in the pictures but I have since had most of them flattened.
    I think that's pretty much it for this project now. Because unfortunately something unexpected happened (loss of my supplemental job!) and I don't really have a use for this machine any more :( So it'll probably just sit in a corner as a spare in case of my main PC goes down.
