Planning X-box 360 mod
Discussion in 'Modding' started by Thatguy119, 17 Apr 2009.
  1. Thatguy119
    Thatguy119 Minimodder
    17 Nov 2008
    Hi, I was just wondering if this has ever been done, or can be done, or do the dimensions just not work.
    Is possible to rip out the inside of an X-box 360 and fit in a working micro ITX system inside, without the exterior appearance changing?
  2. Atheistmunk
    Atheistmunk planing future mod
    27 Feb 2009
    if you plan to put the motherboard in the metal shield inside then yes you could
    it is 27.2cm X 22cm
    but you would have to cut out the ports in the back
