Modding X-box game controler mod
Discussion in 'Modding' started by M_D_K, 17 Feb 2003.
  1. Pliskin
    Pliskin What's a Dremel?
    23 Aug 2003
    when i plugin the homebrew cable... is there supposed to be a new hardware dialog box? and if their isnt supposed to, when i go to install hardware controll panel, and do have from disk, i select the "xid.inf" and then it tells me "The specified location does not contain information about your hardware."
    I installed the registry file first b4 pluging in the adapter, was that a bad thing to do first?
  2. M_D_K
    M_D_K Minimodder
    3 Apr 2002
    basicly wha tyou need to do is match up the cables so each colour goes to its corasponding colour on the usb lead. when you have matched all the colours up you will be left with once colour on the X-box side this isn't ened so cut it off. when you plug it in it should come up with game controler found like you do with any other piece of hardware you plug in then isntall the drivers and away you go.
  3. Pliskin
    23 Aug 2003
    but when i plug the cable in, it dosent pop up nething!
  4. death_star
    death_star What's a Dremel?
    14 Jul 2003
    What OS
  5. Pliskin
    23 Aug 2003
    2000 pro
  6. machman
    machman What's a Dremel?
    12 Jan 2002
    hi all
    could someone post a working link to the xctrl drivers please
    i've tried codeunderground and thats down
    thanks
    Dean
  7. JazzXP
    JazzXP Eh! Steve
    30 Apr 2002
    Look on Google... I found them the other day (took my controller into work) and can't remember the address.
    When I did the mod on mine, I opened up the plug at the end (it just clips apart), and soldered the usb cable directly to the xbox plug, then I put a hole in the side of the plug, and snaped it back together. Means I can still use it on the XBox or the PC.
  8. death_star
    14 Jul 2003
    I wouldnt think it would have the "device auto finder" feature down as "good" as xp.
  9. Pliskin
    23 Aug 2003
    so what can i do?
  10. death_star
    14 Jul 2003
  11. Pliskin
    23 Aug 2003
    I tried intsalling it, same result....
  12. Pistol
    Pistol Guest
    Is there a way to do this with a playstation 2 controller? I always liked those better
  13. Froggy
    Froggy What's a Dremel?
    10 Jun 2003
    umm where did all the newbies come from? anyway, isnt 2000 pro a server os? why would you play games on it?
  14. Fronzel
    Fronzel What's a Dremel?
    9 Mar 2002
    There are adapters to hook a PS2 controller to a PC, There are all sorts of wiring diagrams and Gravis makes a gamepad that is very similar to the PS2 controller.
    Windows 2000 Pro is basically the same as XP home and Pro. Just another name for Windows 2000. A business level OS with a lot of use. I played games on it for a long time. It had the ability to play games and the stability of NT.
    Windows 2000 server is the server OS.
  15. Froggy
    10 Jun 2003
    my bad. i thought that 2000 pro was the server one.
