Graphics x1800xt or 7900gt
Discussion in 'Hardware' started by genesisofthesith, 25 Apr 2006.
  1. genesisofthesith
    genesisofthesith complete spanner
    4 Dec 2004
    which is the better for use with the following system?
    pentium d 920 @ 3.73ghz - stock cooler
    abit lg-81
    2gb pqi turbo memory @ 667mhz 4-4-4-12
    onboard 8mb intel gma950
    160gb maxtor sata2 hdd
    400w jeantech psu
    All this is housed in a aspire x-qpack. If needs be i could replace the psu, but is it really neccesary (was enough to power a 6600gt)
  2. Neogumbercules
    Neogumbercules What's a Dremel?
    14 Aug 2004
    If memory serves me correctly, the 7900GT should have the edge on an x1800xt.
  3. sadffffff
    sadffffff Minimodder
    20 Oct 2003
    although close, the x1800xt beats the 7900gt. get the 512mb version.
    unless youre adding extreme cooling and voltmodding.
    edit: also ati IQ is better at the moment, and they have nifty technological leads such as HDR+AA
    edit(2): the x1800xt MIGHT eat your power supply up though
  4. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    X1800XT stock will be a better option than the 7900GT. If you're wanting to overclock, you'll get MUCH bigger gains from the 7900 than you will the X1800. The 7900 will also run cooler and draw less from your PSU.
    It's swings and roundabouts really. If you're planning on going multi GPU at some point in the future the ATI is probably the best bet, Nvidia + multi GPU + Intel don't really mix too well...
    Also, PSU wise you might well struggle "jeantech" arent usually regarded as high quality PSU makers... 6600GT draws a LOT less than the 7900 will and the X1800 draws even more than the GT...
  5. genesisofthesith
    4 Dec 2004
    I think i will change the PSU now, so no problem there. However is the 7900gt worth the extra £50? With it being cooler I guess that will be better in a matx case.
