Graphics x1900xtx watercooling
Discussion in 'Hardware' started by the_dark, 25 Jul 2006.
  1. the_dark
    the_dark What's a Dremel?
    25 Jul 2006
    :D Hi all....first post....long time lerker. So is anyone watercooling their x1900xtx? If so...what waterblock are you using? Id like to switch over to liquid for this card, but there doesnt seem to be much info around about watercooling it. Thx.
  2. teamtd11
    teamtd11 *Custom User Title*
    31 Aug 2005
    ive heard good things about these
    looks amazing too :D
  3. Fr4nk
    Fr4nk Tyrannosaurus Alan !
    12 Mar 2005
    Yeah alot of people like the EK blocks, I for one don't really liek the look of them but if money is a problem then it would be the option to go with. I'm goign to get a Aquacomputer block for my X1800XT (basically the same blocks are used) as I'm not really worried if it's not as good as an EK block it's roughtly the same price from Aquacomputer.de :)
  4. needmorstuff
    needmorstuff What's a Dremel?
    23 Jan 2004
    I have one of the ek blocks for my x1900 - looks good and is 1/2" with low restriction. What ID tubing are you going to use?
    the german blocks are very well engineered but I had issues as the screws that went through the block were always too wide for my card of choice at the time (6800gt) so I had to drill the holes a bit wider - :eek:
  5. the_dark
    25 Jul 2006
    thx for the direction guys.....havent decided on size tube yet Needmor, ive got a lot of room in the case so maybe 1/2.
