Motherboards x79 sabertooth thermal radar problems
Discussion in 'Hardware' started by HandMadeAndroid, 28 Jan 2012.
  1. HandMadeAndroid
    HandMadeAndroid That's handy.
    18 Feb 2005
    Hi there,
    I've just upgraded to a 3930k running on a sabertooth board. The system is up and running fine apart from the 'thermal radar' software. I can't get the fans to slow down, thus the system sounds like a wind tunnel and is driving me mad! I've tried every combination of settings, has anyone any suggestions?
    edit h100 fans suck...buyer beware
  2. improprietary
    improprietary FT03 is a bitch to watercool
    13 May 2011
    i use noctua's in my h80 but i hear ALOT of praise to the gentle typhoons... 1850 rpms i think it was
  3. x_stefano20
    x_stefano20 What's a Dremel?
    5 Feb 2012
    I have the same configuration, in my system the windows based software thermal radar doesnt work at all ! when I try to activate it this error appear Unable to start sever, prog,id:"Asusfancontrolservice.fancontrolmanager"
    my cpu cooler is a corsair hn100
    did you solve your trouble ?
    did you try to modify bios setting to solve fan noise ?
    By
    Stefano Roma Italy
    :wallbash:
  4. merophosis
    merophosis What's a Dremel?
    11 Mar 2012
    I too, can't launch my Thermal Radar and receive the same error.
    Did you find a fix yet? I can't seem to figure this out.
  5. rollo
    rollo Modder
    16 May 2008
    you can switch the fans on the h100 using the profile switch on top of the cpu
    low medium high
    will always sound like a windtunnel when powering up though
  6. Jasio
    Jasio Made in Canada
    27 Jun 2008
    The Gentle Typhoons are better on any rad than the Noctua P12's- which are more suited for air cooling. The 1850's are a very nice mix between noise and performance and I use them on my H100 in a push/pull config (4 fans + extra set of H100 fan mount screws from Corsair).
  7. JohnSheridan
    JohnSheridan What's a Dremel?
    30 Dec 2010
    I have that board and used the advanced setting in the bios to set the fan speeds. My problem was an error on boot as the fans were spinning too slowly for the bios' liking!
  8. Guest-16
    Guest-16 Guest
    I have asked the Sabertooth RD team to have a look at this thread, so any extra info you guys can provide please say. Thanks.
  9. Guest-16
    Guest-16 Guest
    The error is produced because the CPU fan connector does not support 3pin (DC control) fans, only 4pin (PWM) as it follows Intel spec. Change the fan to 4pin or the connector to CPU_OPT or another chassis fan one. For the H100 the pump connected to the CPU_OPT is advised.
    Go into BIOS=>Advanced Mode=>Monitor=>CPU Fan Speed Low Limit, and set the item from “600rpm” to “ignore”.
    Thermal Radar v1.01.09 should be released shortly that fixes your issues HandMadeAndroid. :)
