Graphics x850xt/pe pci-e + crossfire or...
Discussion in 'Hardware' started by aevitas, 19 Jun 2005.
  1. aevitas
    aevitas What's a Dremel?
    6 Mar 2005
    the r520 + crossfirecard?
    What would be the best ? I heard the r520 will > all other ati cards.. but will it be worth the wait?
    I am considering of buying the x850xt/pe platinum pci-e and then the crossfire mobo + crossfire card.. since they will be here within 3 weeks or so I am really interested in that..
    And I don't know how long the r520 will take? So will it be worth the waiting for the r520 or should I buy the x850xt/pe pci-e?
    :confused: :confused:
  2. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    The R520 should be a beast of a card (if as we are lead to believe it will be faster than the G70 (7800 GTX)) There are some benchmarks available with a heavily overclocked X850 crossfire based system, scoring a little over 15k in 3dmark 05.
    I notice you currently have a X850 PCI-e card, why not grab a crossfire mobo now, and use the current card until the R520 emerges. You'll have first hand benchies then, to make your mind up with. In the mean time, a single X850 isnt exactly slow is it ;)
    If you decide the R520 isnt the way to go, then add an X850 based crossfire master card for dually action....
