XARIG AQUA-SLI MKII - CPU Update
Discussion in 'Project Logs' started by Xarig, 30 Jan 2005.
Which hard drive housing?
Poll closed 11 Feb 2005.
  1. Silentmaxx
    6 vote(s)
    14.6%
  2. Aqua computer
    35 vote(s)
    85.4%
  1. Xarig
    Xarig New Member
    26 Feb 2003
    Sitckeh - Photos are on email to you.
    Update coming soon.
    Taking my son to Pizza Hut for his birthday lunch now - his choice - works for me :hehe:
  2. Pitbull
    Pitbull New Member
    20 Mar 2005
    nice nice nice :hehe:
  3. Xarig
    Xarig New Member
    26 Feb 2003
    As promised, an update :rock:
    Okay, so I didn't have time to dry test my new kit - but I agree with you all and that's a must before I start hacking and modding!
    Today I completed a couple of small jobs:
    I lapped my blocks, here's what it looked like before
    and after:
    Then I got to work with my new toy:
    As I explained before the case has a bevel to the front, so I want to keep the drive bay cover in keeping with this shape. The following pics tell the story:
    I then heated the plexi with my gun :dremel: and clamped it against the drive bay covers to get the correct curve. This wasn't easy, hence no pics. Eventually I got the desired curve.
    Next I made an aluminium DVD drive tray cover, this will of course be visiting the chrome meister :naughty:
    There's still lots to do on this particular part of the mod and I've got an idea to liven up the areas between the Aquero and DVD drive tray. I'm afraid an etching is not really an option, so I've got an alternative idea........... watch this space.
    PS. Having reservations about the name - anybody got any better ideas?
  4. Franklin
    Franklin New Member
    24 Oct 2004
    I can't see Aquacomputer anymore right now. I'm waiting more then a month now for my stuff :waah: :waah: :waah: I can't mod on without the AQ parts, I need them for the precise sizes of the blocks. :wallbash: :wallbash:
  5. Xarig
    Xarig New Member
    26 Feb 2003
    Try contacting Jessica at Leftclicks.co.uk I'm pretty sure she'd ship to the Netherlands. I know PayPal costs a bit but for me it was much cheaper than the cost of a Euro bank transfer (I guess that might not be true for you though).
    Worth a try, I'd say :thumb:
  6. Franklin
    Franklin New Member
    24 Oct 2004
    I ordered it directly from Aqua computers in Germany and its already paid for. They didn't have the two aquagraFX 6800 Revision 2 coolers.
  7. leviathan18
    leviathan18 New Member
    17 Mar 2005
    your son rox pizza hut rox and i want lunch there in my birthday too :rock:
    well back to mod :dremel:
    i think your h20 flow will decrease a lot... unless your pump is bigh enough for that task... perhaps another pump will help a lot
    something like this:
    cpu and video 1 with one pump and one radiator
    video 2 mobo and hdd with anothe pump and another radiator should be fine...
  8. sc4mpi
    sc4mpi OG watercooler
    16 Jan 2005
    Its 10mm diameter tubing it will be fine with the one pump ,2 pumps on 10mm is overkill unless you have a excess of blocks and this dosent appear to be excessive. :hehe:
    P.s 10mm ac and innovatek is designed to work well with low flow systems,
    Nice mod so far cant wait to see it with every thing in :D
  9. Jumeira_Johnny
    Jumeira_Johnny 16032 - High plains drifter
    13 Nov 2004
    Great lap dance :wallbash: :rolleyes: , I mean lap job in the blocks. This looks like it's starting to come together. :thumb:
  10. Xarig
    Xarig New Member
    26 Feb 2003
    Me lose a star :waah:
    Perhaps an update will get it back :confused:
  11. Franklin
    Franklin New Member
    24 Oct 2004
    :hehe: :hehe: :hehe: There seems to be a very critical visitor on Bit-tech Xarig, my rating dropped quite a bit too. But who cares, just keep up the good work and have fun modding.
  12. Xarig
    Xarig New Member
    26 Feb 2003
    Will post some pics in a minute
  13. Xarig
    Xarig New Member
    26 Feb 2003
    :rock: As promised here are some more pics:
    I took your collective advice and built up the rig for a 'dry run':
    I love the way the motherboard reflects in the floor - can't wait to see it with the cooling loop in place :D
    Feel the power :naughty: :naughty:
    Okay ready to go.
    Let's fire her up......
    She's alive! :rock: :rock: :rock:
    'raw' drivers, no tweaking or overclocking yielded a 3Dmark05 score of 8915 :) can't wait to see what this can really achieve.
  14. Firehed
    15 Feb 2004
    Why do you have the ram in single channel?! Come to think of it.. that ram is really wierd looking too... the only thing with top similar to that I've seen is the Corsair Pro which that certainly isn't.
    Anyways, glad to know it works.
    The A8N can overclock quite well if you don't try and run 1T ram timings... which should be fixed with the upcoming (or maybe even released by now) 1007 bios. And anyways, you just CAN'T fit a chipset waterblock to the DFI since it would hit the second graphics card, which is a big downer for it.
  15. Xarig
    Xarig New Member
    26 Feb 2003
    The ram is - Corsair 1GB DDR XMS4400 TwinX (2x512MB) CAS2.5 (TWINX1024-4400C25PT) (MY-068-CS) ....and there's another 1GB on the way, arriving tomorrow I hope :naughty: :naughty:
    Not quite sure what you mean about the single channel? This is the way the maual said two DIMMS should be installed :confused: Seems to work :thumb:
    I'm pretty new to the whole overclocking scene - thought I'd jump in with both feet :worried: :worried: What are 1T ram timings?
  16. Xarig
    Xarig New Member
    26 Feb 2003
    Firehed, just checked the manual again, definatley nned to install DIMMs in DIMM_A1 and DIMM_B1 (chapter2-11). The sum of A1 + A2 must be the same as B1 + B2 to get the dual channel enhanced performance.
  17. Franklin
    Franklin New Member
    24 Oct 2004
    Yes the manual says:"When using two DDR DIMM modules, install into DIMM_A1 DIMM_B1 slots only"
  18. Firehed
    15 Feb 2004
    ie the blue ones
    But to warn you, it'll get bumped down to PC2700/DDR333 when you go for the four sticks :grr:
  19. Sanatarium
    Sanatarium The Artist Formerly ATi_Loyalist
    22 Feb 2005
    Very cool, the mirror blue on black is sick!! Great work on the color scheme.
  20. Xarig
    Xarig New Member
    26 Feb 2003
    They're snug in the blue ones.
    Why do they get bumped down? Where can I find out more about this?
    Thanks
