News Xbox 360 bundle announced
Discussion in 'Article Discussion' started by WilHarris, 27 Jul 2005.
  1. WilHarris
    WilHarris Just another nobody Moderator
    16 Jun 2001
  2. mclean007
    mclean007 Officious Bystander
    22 May 2003
    no DVI! Why? WHY! Microsoft, what a senseless waste... :waah: :waah: :waah: :waah: :waah: :D
  3. The_Pope
    The_Pope Geoff Richards Super Moderator
    3 Jul 2003
    Why do you want DVI for an Xbox 360 so desperately?
  4. NuTech
    NuTech Minimodder
    18 Mar 2002
    Don't know about him, but I was hoping for a DVI or HDMI output so I could plug it into a LCD monitor, doubt I'll be able to afford a HDTV for a while.
    However I'm sure there will be some way for us to plug it into a monitor and enjoy HD resolutions.
  5. mclean007
    22 May 2003
    My reason is a little less practical than NuTech's - sure, it would be great to be able to plug an xbox 360 into a 50" HD screen via a digital connector, but (a) I am in no position to afford an HD screen at the moment, and (b) even if I had one, I doubt I'd be complaining too hard about having to 'settle' for component video.
    However, I can't help but feel that MS will be missing a trick if they fail to put a digital connector on the 360 - I mean, it's the zenith of technology in so many ways, yet they aren't fitting what would surely be a very cheap bit of circuitry to drive a digital connector.
    Also, if implemented in the xbox 360, digital video connection standards for consumer electronics would get such a boost in their widespread availability that we might see DVI/HDMI filter down to the budget end of technology more quickly, which can never be a bad thing.
    EDIT: plus it would be so frickin' cool
  6. Guest-16
    Guest-16 Guest
    You can convert component into DVI i think. Gamecube used to have a digital out on it and that can output component and HDMI from the same connector so they must be "similar" (long shot there).
    You just know 90% of people will be happy with composite though :rolleyes:
  7. Flibblebot
    Flibblebot Smile with me
    19 Apr 2005
    Personally, and for the timebeing, I'd be happy if it comes with a SCART connector that I don't have to pay extra for :D
  8. Guest-16
    Guest-16 Guest
    Well, the Xbox comes with a SCART adapter, rather than cable (or at least mine did).
    Mmm composite SCART, just as ********.
  9. DougEdey
    5 Jul 2005
    I'd be very happy for it to come with teh DVI connector, my projector loses a lot of quality off the AV standard cables.
    But with Microsoft saying EVERY game will be HDTV compatible, surely they should give the correct connector
  10. mclean007
    22 May 2003
    True, but component is compatible with HDTV resolutions - it's just that it's analogue rather than digital. So if component is there, then MS can legitimately say it's HDTV compatible.
  11. Fod
    Fod what is the cheesecake?
    26 Aug 2004
    if i get an xbox 360 it will most probably be kept by my computer hooked upto my monitor. since i use the DVI connection already, i'll use the D-SUB connection, but yeah, i agree that this console should have DVI, i mean, it's designed to be hooked up to HDTVs right? well pretty much the only HDTV compatible displays in europe right now are plasma and TFT... and everyone knows they all work best with digital connections.
Tags: Add Tags
