Electronics xbox 360 component to vga
Discussion in 'Modding' started by Snipes0990, 5 Dec 2005.
  1. Snipes0990
    Snipes0990 What's a Dremel?
    4 Oct 2005
    i want to make a component to vga adapter and i was wondering if anyone had a link to where i could find which pins i need to solder the component signal cables to. i am goin to try google but i was just wondering if anyone has done this before and how it worked, i know it can be done because they sell cables like this already
  2. Wolfe
    Wolfe What's a Dremel?
    7 Sep 2003
    You need a special converter.
    Component video is sync-on-green, meaning the v and h sync information is transfered on the same cable that carries the green intensity information.
    VGA has both v-sync and h-sync broken out in individual cables.
    IOW, you have to buy a converter, which typically runs something like $50.
    As far as i know with the x-box, the vga output and the component output uses different pins in the output connector. It's not actually converting one to the other.
  3. thecrownles
    thecrownles What's a Relix?
    27 Feb 2004
    I believe your converter is called the VD-Z3 (try googling that), I haven't got one to test though, so you're on your own as to whether or not it works with your box.
  4. BlitzenWagon
    BlitzenWagon What's a Dremel?
    2 Nov 2005
    why not just buy the VGA cable specifically made for the 360?! its probably like $20-30. check xbox-scene i saw something about this.
    ah here you go: VGA
    and RGB
    Oh and by the way on those schematics the link is used to tell the xbox what cable its using and what modes to enable.
