Xbox 360 xbox 360 hdd interchangeable??
Discussion in 'Gaming' started by failsaif1924, 26 Oct 2007.
  1. failsaif1924
    failsaif1924 What's a Dremel?
    10 Jul 2007
    can you put a 120gb hdd from the elite on a non elite 360?
  2. ArtificialHero
    ArtificialHero We were just punking him sir!
    25 May 2004
    It's the same HDD that you can buy separately, so yes.
  3. failsaif1924
    10 Jul 2007
    hmm, so wat about buying a sata 120gb hdd and fitting it ureself? that possible?
  4. ArtificialHero
    25 May 2004
    Don't think so. If it's possible it will be documented on www.xbox-scene.com. I can't be bothered to check though, have a look for yourself.
    AH
  5. cmberry20
    cmberry20 Mad Scientist
    16 Jul 2007
    Yes, it is possible.... clicky
  6. Veles
    Veles DUR HUR
    18 Nov 2005
    It's possible but only certain hard drives will work
  7. fwalm
    fwalm What's a Dremel?
    4 Jan 2007
    Plus you have to flash your harddrive do you not? Meaning a ban if you do anything bad.
  8. WireFrame
    WireFrame <b>PermaBanned</b>
    24 Feb 2003
    That makes no sense at all.
  9. DougEdey
    5 Jul 2005
    Fixed
  10. Veles
    Veles DUR HUR
    18 Nov 2005
    Don't think you have to flash your hard drive, you just need to buy the same one they use in the 120Gb unit (not difficult, it's readily available if you can find out what the specific model is, I've forgotten now) and then you just need to copy the data that's on the 20Gb hard drive (emulation data, etc.) and that supposedly works fine. Or alternatively, you can buy it cheap off ebay (like here and then buy a transfer cable off the bay as well (only cost around a tenner then you can resell it).
  11. DougEdey
    5 Jul 2005
    You do have to flash the drives BIOS
  12. failsaif1924
    10 Jul 2007
    ok thnx for all replies, ive done a bit of research and im a bit confused, some places say you can use the flash data off a 20gb model but only 20gb will be accesible ... what i dont get is people coninue to use bigger drives even though only 20gb is accesible... is there something really obvious that im missing?
  13. DougEdey
    5 Jul 2005
    they are waiting on the bios from the larger drives becoming freely available.
