Modding XBox 360 - Need rubber "U-Channel" for case window - Best place to get it?
Discussion in 'Modding' started by FIBRE+, 17 Apr 2009.
  1. FIBRE+
    FIBRE+ Minimodder
    27 Feb 2005
    I need about 40cm of rubber "U-Channel" for a case window on an XBox 360, the case is about 3mm thick and I would prefer if it was fairly low profile on the outside.
    Where is best to get it (cheap), or does anyone have any spare they went to sell? :p
    My Brothers Elite decided to RROD, I decided to go a bit further than the X-Clamp fix and fit an aftermarket fan, heatsinks on all the critical chips, and i've just cut a hole to fit an LED lit window (with holes for ventilation).
  2. FIBRE+
    FIBRE+ Minimodder
    27 Feb 2005
    Looks like I got the terminology wrong to start with, I've found a few places now but any recommendations would still be useful.
  3. mansueto
    mansueto Too broke to mod
    31 Aug 2007
    I know the mnpctech used to, not sure if they still do though
  4. MikeMania
    MikeMania What's a Dremel?
    25 Feb 2009
  5. jhanlon303
    7 Sep 2006
    + Bill ships worldwide. Check it out.
    john
  6. shata
    shata What's a Dremel?
    6 Jul 2012
