Xbox 360 Xbox 360 on 17inch LCD
Discussion in 'Gaming' started by mendreks, 1 Apr 2006.
  1. mendreks
    mendreks What's a Dremel?
    9 Oct 2005
    is it possible to play xbox 360 on my 17 inch LCD screen i use for my computer? and will i get a HD picture?
    Thanks
  2. Stickeh
    Stickeh Help me , Help you.
    20 Jul 2003
    yes and yes.
    vga cable.
    did it on my 18" CRT looked amaziiiiiiiiiing. GRAW = :O
  3. mendreks
    9 Oct 2005
    sweet thanks.
  4. mookboy
    mookboy BRAAAAAAP
    15 Feb 2002
    Provided your 17inch LCD has a high enough res then you ought to be able to get any of the HD pictures in the equivilant resolution (I suspect you may be limited to 720p = 1024x720).
  5. mendreks
    9 Oct 2005
    my LCD's max res is 1280 x 1024 what res will my 360 run at?
  6. mushky
    mushky gimme snails
    24 Mar 2003
    Set it to 1280 x 1024 in the dashboard.
  7. Cheese
    Cheese Doc
    6 Oct 2001
    Sure, but all the games will run in a window at 1280x720.
    17" LCD is fine if you've nothing else, it will be better than a CRT TV no doubt - when I first got my 360 I used a 17" LCD.
    I use an acer wdiescreen 19" LCD now, the resolution isn't perfect (scales 1280x768 to 1440x900 native of the display) but it's pretty damn good.
  8. mushky
    mushky gimme snails
    24 Mar 2003
    Some games run in 4:3 and some in 16:9 when you use higher 4:3 resolutions. Not sure why that is but it's certainly not all games that do it. Some games will run in 4:3 when set to 4:3 but only at lower resolutions.
    Using a proper widescreen monitor is advisable, especially if you want HD seeing as the true HD resolutions are 16:9.
