Modding xbox 360 wireless controller mod question!! PLEASE HELP
Discussion in 'Modding' started by snitzl3, 21 Aug 2007.
  1. snitzl3
    snitzl3 What's a Dremel?
    21 Aug 2007
    ok this is a really random idea for a modd but i was wondering if its even possible..ok heres my idea..the other night me and one of my friends were playin gears of war, i was just messin around and everytime my friend would shoot his gun i would turn on my strobe light that i have behind my tv...it was so freaking cool lookin it actually felt like the machine gun was being fired..So here's my question, is it possible to somehow intercept the right trigger signal and have it trigger a switch whenever its pressed to turn on and off power to my strobe light? If anyone has any comments or ideas or any useful info (such as hardware suggestions, what kind of signals the controller operates on, etc.) that could help would be great. Thanks in advance.
  2. MiT
    MiT Don't feed me after midnight!! nom
    18 May 2005
  3. snitzl3
    21 Aug 2007
    yeah ive posted on there also, i was just trying to broaden my search so hopefully i could get a solution.
  4. DougEdey
    5 Jul 2005
    Easily done, make it intercept the voltage to the rumble feedback.
  5. 500mph
    500mph The Right man in the Wrong place
    22 Jun 2007
    its actually pretty easy, i can think of it in my head, using a separate trigger inside the controller, or intercepting the signal to the rumble pack as said above, lol.
    btw, is your name seth?
  6. tranc3
    tranc3 ADHD Modder
    16 Jul 2007
    you could, use a one of those things that pick up sound and transmit it to the power or w/e and run yuor strobbe light threw that. so then grenades and other "load" noises will react to it.
    good idead, and yea is you name seth+ are your form Virginia ?
  7. snitzl3
    21 Aug 2007
    thanks for the replies ill have to do some testing and such...and no my name is not seth...my name is tim...and im from mississippi
  8. 500mph
    22 Jun 2007
    ah, ok then, good luck
    and we thought your name mightve been seth cause one of our friends nickname is Schnitzal, and he plays gears often.
  9. snitzl3
    21 Aug 2007
    its cool
  10. jakenbake
    jakenbake full duplex
    5 Jun 2005
    intercept the voltage from the rumble, send it to a wireless transmitter (and locate the Tx under the controller?), have a receiver accept the transmitted message, and then have a relay flip the light on and off
  11. snitzl3
    21 Aug 2007
    will that work everytime i use the right trigger or just whenever the controller vibrates
  12. jakenbake
    5 Jun 2005
    it would only work when the controller vibrates, but doesn't it vibrate every time you pull the trigger?
    i guess you could go off the trigger pull, but i would think that would be harder b/c you're going from a (assumed) small voltage signal instead of a normal voltage to the 'rumbler'
  13. snitzl3
    21 Aug 2007
    i dont think it vibrates for every gun...im trying to create the affect of a gun being fired with the flash of the strobe...only way i could think of doing that is to go off the right trigger
