Xbox 360 Xbox and DivX playback
Discussion in 'Gaming' started by manatwork, 2 Jun 2008.
  1. manatwork
    manatwork What's a Dremel?
    21 May 2008
    Although I have the Fall 2007 system on my xbox 360, it can't play AVI/DIVx videos and says I need an update. What is it talking about.
  2. DougEdey
    5 Jul 2005
    How are you sharing them from the host PC?
  3. liratheal
    liratheal Sharing is Caring
    20 Nov 2005
    A friend of mine has that issue, but even with the update installed, it has no effect.
    The update is listed on the XBL system as Optional Media Update or something. If you've got that installed.. Then you're in the same boat as my friend. No idea as to the solution yet.
  4. M4RTIN
    M4RTIN What's a Dremel?
    11 Sep 2006
    for some reason mine will only play them when its connected to live, if it's not then i'll have that same thing come up, maybe thats the problem your having? its odd tho
  5. DougEdey
    5 Jul 2005
    Can you guys use the Gspot Application to check the Audio and video information and report back what it says please?
  6. M4RTIN
    11 Sep 2006
    which bit do you want the info from.. heres the screenshot of it all on a divx of pulp fiction
  7. DougEdey
    5 Jul 2005
    What are you using to share the media? What OS and what software application?
  8. M4RTIN
    11 Sep 2006
    i dont know about anyone else but i dont know how to stream divx from vista to the xbox, media centre wont allow it, in fact it only really seems to allow wmv. i use a usb external hard drive for videos and music on the 360. but this same problem occurs if the files are on cd's or dvd's too.
  9. DougEdey
    5 Jul 2005
    There's an update required for the PC side of it I think. But I never got it to work on Vista Business at all. You can try Windows Media Connect, but I doubt it'll be any good. Look at a uPnP server software, there may be a trial that would work. But I have a Linux system with uPnP (uShare) and it streams perfectly.
  10. Hex
    Hex Paul?! Super Moderator
    11 Jan 2002
    You could give TVersity a go. I've got it working with other devices, but the 360 doesn't seem to like it streaming from a win2k machine :(
  11. manatwork
    21 May 2008
    i just have the avi files on a dvd or a memory card and then i connect to 360.
  12. liratheal
    20 Nov 2005
    My issue with TVersity is how much it stores in its own directory.
    My install directory for TVersity, no matter what I changed, went north of 4gb :/
