Peripherals XBOX controller when used in windows 10 (RT) button issue
Discussion in 'Hardware' started by kuroidoragon, 30 Dec 2019.
  1. kuroidoragon
    kuroidoragon Minimodder
    14 Oct 2012
    on a XBOX controller when used in windows 10
    is there a way even with other software if need be to disable the physical RT button on the controller but still have the functionality on another button ?
    because I think my RT trigger is borked somehow as when playing the division 2 my weapons quite often fire by themselves or the game map zooms in by itself
    I believe this is the one I have if it helps
    https://www.powera.com/products/enhanced-wired-controller-for-xbox-one-black/
  2. Mr Meltdown
    Mr Meltdown Minimodder
    26 Jul 2003
    Probably a physical problem with the controller, make sure trigger isnt binding on controller shell for starters. Otherwise open it and check trigger pot etc.
    Edit: assumed RT meant right trigger, if you mean the button above trigger then same deal except bend the button switch mountings.
    kuroidoragon likes this.
  3. kuroidoragon
    14 Oct 2012
    I am pretty sure it is a bug with Division 2 I haven't noticed it with any other game & when playing Division 2 as long as I don't push that button it seems fine
    just need to get another controller to see if it behaves the same way or not to be sure
  4. Anfield
    Anfield Multimodder
    15 Jan 2010
  5. kuroidoragon
    14 Oct 2012
    I got that app during my google searches today as far as I am aware it does not let you completley disable individual buttons
  6. Anfield
    Anfield Multimodder
    15 Jan 2010
    Remap it to be something meaningless like F10?
  7. kuroidoragon
    14 Oct 2012
    I dont think you can remap in division 2 the controller settings it just has different loadouts you can try
    unless you mean do it out of game but I don't know how to do that
  8. silk186
    silk186 Derp
    1 Dec 2014
    Would something like Xpadder let you map the trigger to a random keyboard key?
  9. kuroidoragon
    14 Oct 2012
    maybe if I didn't have to pay for it
  10. Vault-Tec
    30 Aug 2015
    If you're getting issues like these take it apart and blow it out. I had stick drift and that worked for me. You should also use a contact cleaner.
