Modding Xbox Mods?
Discussion in 'Modding' started by Fowler, 5 Jan 2004.
  1. Fowler
    Fowler mmm Cosworth
    20 Nov 2002
    Anyone looked into this? Ive seen some alternative skins but wondered if anyone had done anything custom around here?
    :D
  2. apoogod
    apoogod trix arent just for kids
    19 Jun 2002
  3. japala
    japala What's a Dremel?
    8 Dec 2001
  4. RobbieGSM
    RobbieGSM Banned
    26 Nov 2003
    think im going to do that light plug mod to my pad :D:p
  5. apoogod
    19 Jun 2002
    here are some xbox replacement jewels I did
  6. RobbieGSM
    RobbieGSM Banned
    26 Nov 2003
    Nice!
  7. Malvolio
    Malvolio .
    14 Dec 2003
    Just figured I'd put in my two pence here. All the xbox modding sites I've found so far, only give you a guide on how to change the color on one of the two front status LED's. The cable bounch I'm reffering to is the small yellow one that goes from the front pannel, and down onto the xbox's mobo. Pin 1 is indicated by a very small arrow, but it's easy to tell anyway, as the hole for pin 10 doesn't have a wire going into it. Using a multimeter, I've figured out that if you swtich 5 and 6 arround, the LED on the left will change from red to green. When you switch 7 and 8 you change the LED on the right.
  8. ajack
    ajack rox
    17 Apr 2003
    Yep Malfoleo i saw that one on Xbox Scene a while ago, still need to replace the leds with blue ones though
  9. BioSniper
    BioSniper Minimodder
    5 Feb 2002
    I do love those jewels apoogod :)
    I assume they are just plexi etched or similar as I was thinking of making my own.
    There are some very well done paint jobs on Xbox scene site there I must say.
    I have been thinking of doing an XBOX mod myself actually but I want it to be something more special than just a simple paint job/CCFL/LED's
    *looks to G-Gnome for inspiration* ;)
  10. malcs
    malcs oops! i put a hole in the ***** :(
    24 May 2003
    i modded a pad :) am modding a PSone atm but youll have to wait to see the finished articles
  11. JazzXP
    JazzXP Eh! Steve
    30 Apr 2002
    I'd like to put an EL light under the jewel on mine, maybe even have it pulse with hard drive usage... I probably will never do it though.
    I love that imperial jewel too apoogod.
  12. apoogod
    19 Jun 2002
    tx guy....thell be up on the site again when its done....Jazz you could allways put a CCFL under the jewel....works great to light the jewels up, thou not sure how you would get it to flash
  13. JazzXP
    JazzXP Eh! Steve
    30 Apr 2002
    Yeah, I thought of that... I was just thinking that EL would give a bit more of an even glow.... I probably won't do it though.
  14. Lazlow
    Lazlow I have a dremel.
    8 Aug 2003
  15. death_star
    death_star What's a Dremel?
    14 Jul 2003
    Ive cut windows into my xbox and painted it with flames. Gonna add lighting soon and have done mods to the front light things. Look at my gallery at xbox-source.net to see it (I didnt wanna waste my limited bandwith)
  16. Fronzel
    Fronzel What's a Dremel?
    9 Mar 2002
    I've noticed the X-box doesn't like more then 128 meg of RAM. I guess it runs out of adresses. It also only likes Celeron processors. Or, it likes them better. I found the USB bus to be flakey, but between USB, my drivers, and Microsoft, it didn't stand a chance.
