Xbox One Xbox One controller
Discussion in 'Gaming' started by goldstar0011, 9 Feb 2015.
  1. goldstar0011
    goldstar0011 Multimodder
    2 Sep 2007
    Hoping someone can direct me to the best place to get an official xbox one controller as cheap as possible.
    Cheers
  2. MadGinga
    MadGinga oooh whats this do?
    19 Mar 2009
    Wired or wireless?
    PC or Xbox One?
  3. goldstar0011
    2 Sep 2007
    Didn't know they did wired one, after wireless and not aware they is a pc specific controller
  4. MeddlE
    MeddlE Norwegian Blue
    23 May 2011
    Got mine from Amazon. They are pretty much the same price everywhere. No difference between console version and PC version unless you require the battery. They use a standard USB connection so the 'official' cable is not required.
  5. Hex
    Hex Paul?! Super Moderator
    11 Jan 2002
    As far as I can tell all Xbox One controllers are wireless, they have a micro-USB port on them that can be used to make them wired. They're also compatible with PC, plug & play.
    As for the cheapest place, really not sure. Probably Amazon.
  6. MadGinga
    19 Mar 2009
    Sorry, my understanding was that they were different, my bad :(
    I also thought that the PC didn't have drivers/support wireless (yet), or am I wrong there too?
  7. MeddlE
    23 May 2011
    Correct on that one, no wireless support for PC.
  8. Hex
    11 Jan 2002
    I wasn't sure on that, never used a wireless one (can't stand wireless controllers). I know the 360 controllers had a wireless adapter, but I always had wired ones anyway. My Xbox One controller works fine plugged into my PC with a USB cable.
  9. Margo Baggins
    Margo Baggins I'm good at Soldering Super Moderator
    28 May 2010
  10. MeddlE
    23 May 2011
  11. MadGinga
    19 Mar 2009
    Not wirelessly, no. But yes if you connect via a micro USB cable...
  12. MeddlE
    23 May 2011
    If you read the thread you'll see that the fact it works on PC is already covered. Hence there being a PC version.
  13. dynamis_dk
    dynamis_dk Grr... Grumpy!!
    23 Nov 2005
  14. MeddlE
    23 May 2011
