I have a One X, today I went to power it on and I heard the usual chime when you press it. The Xbox logo button and the white led came on as it should however before anything came up on screen it switched itself off. So I switched it on again and this time the white led came on for no more than a second before going off. I tried it again and now no light or sound or anything. A month ago I opened it up cleaned it out and changed the HDD and I used it immediately after I did that for over an hour and it was fine. I haven't used it since so it was sat switched off for a month and then today no power. I tried another power cable however same issue One thing to note is the eject button never worked and I would always have to eject from menu. I have since done a complete dis and reassembly to ensure everything was plugged in correctly as I know there are a couple ribbon cables in there. They were all in place so it wasn't that. Any ideas?
Sounds like a small board component has gone pop. Difficult to say without having it inspected under a scope. Could be a cap or a fuse? Speculating here but I've had previous experience with similar symptoms on my old PS4 and it was a small capacitor that had failed. The component was pennies but the repair not so much! Easily replaced by a professional electronics repairer though, if that is indeed what it is.
I found out that it is the HDMI Retimer IC Control Chip which a known/common fault with these. It usually results in no picture being displayed though can also cause no power as in my case. The chip itself isn't too expensive to purchase though as you say it is the repair which can be costly. Unless you can do it yourself, it's not something i've done before so I may end up selling the console only as faulty. I bought another One X though I notice that with this other one it won't allow me to display 4k, only upto 1440p so I reckon its the same cause... as some have had issues where it will only display 640x480 and this chip was the culprit so it appears to be a ticking time-bomb. Also, I've found that some of those who have replaced theirs have gone again sometimes only a few months later.
