Graphics XFX 4870
Discussion in 'Hardware' started by joco2_uk, 1 May 2012.
  1. joco2_uk
    joco2_uk What's a Dremel?
    1 Sep 2009
    Hi,
    I've got a 512mb XFX 4870 and was wondering what card you could compare it to now a days. I know it cant do DX11 but other than that?
    Let me know what you think.
  2. Blogins
    Blogins Panda have Guns
    3 Aug 2010
    At a rough guess I would say a 768MB GTX 460, but bear in mind these are over priced these days anyway!
    Were you looking for a decent upgrade suggestion?
  3. joco2_uk
    1 Sep 2009
    Yeah, was thinking of upgrading, either buy new or look at ebay. Was thinking of a 6870.
  4. mrbungle
    20 Sep 2004
    the 460 GTX smokes a HD4870 :p
    a 6870 is a bit faster than a 460 GTX still so would make a good upgrade imo, keep a eye on ebay I have one in a 2nd machine I got for peanuts.
  5. docodine
    docodine killed a guy once
    10 Feb 2007
    It's about equivalent to a 550ti
  6. Blogins
    3 Aug 2010
    What's your budget and the rest of your system specification?
  7. Williz
    Williz Minimodder
    9 Mar 2012
    You can grab 6870's on eBay for around £100 if you're lucky. I recently managed to grab 2 off there to upgrade my (funnily enough) 4890's. Also managed to get the Asus Crosshair V mobo for £120 brand new.
  8. joco2_uk
    1 Sep 2009
    You got a crosshair new. Wow you were lucky dude! I think aria has the xfx 6870 for around £118 just now. Not a bad price i think.
  9. joco2_uk
    1 Sep 2009
  10. Parge
    16 Jul 2010
  11. joco2_uk
    1 Sep 2009
    You think it will play modern games at a decent level? I'm using a 22" 1680x1050 monitor.
  12. Parge
    16 Jul 2010
    Yes. Especially if your monitor is the above resolution. You can check how much faster it is on the Anandtech test bench
    What games are you thinking of getting?
  13. joco2_uk
    1 Sep 2009
    Thanks for the link btw.
    Maybe some BF3, some crysis 2 and I've always like supreme commander.
  14. Parge
    16 Jul 2010
    Those are pretty high end games. £75 is a bargain for that card though, and since you are only running 1680x1050 I should think you'll be ok.
    If you plan on getting a new monitor anytime soon, you should maybe think about a 560ti or something. If you buy second hand, they can be had for about £100.
