Hey, Would the two above components be able to fit inside the Antec P182? I'll be removing the upper internal drive cage so the graphics should fit, but would the cooler get in the way, and is the cooler small enough to fit in the P182? I've searched around and it seems there's a mixture of people who have been able to get it to fit . . . If not, do you guys recommend a similar priced case which got almost as good a review as the P182 which will accommodate my components? Thanks, Aleph Haz
