Hardware XFX nForce 680i SLI
Discussion in 'Article Discussion' started by Tim S, 27 Jun 2007.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. Guest-23315
    Guest-23315 Guest
    Do we really need constant reviews of all of the referance design 680i boards?
    Anywho, good review as allways!
  3. Guest-16
    Guest-16 Guest
    I know what you mean, but this goes back to CeBit and my conversation with XFX went something like this:
    Bindi: "Send us something interesting!"
    XFX: "k, we have a pre-overclocked (???) LT board coming soon"
    Bindi: "Sounds great, send it on"
    Two months later we get a plain Jane 680i in the post and I don't check the box til I come to review it :(:(
    Anywaaaay, at least this lets you know the differences aren't that much across the entire range and the whole difference is in the packaging. It's still good to know there isn't much to know, right? :)
  4. trig
    trig god's little mistake
    10 Aug 2006
    ok, what are the differences between all the evga 680i boards on newegg? there are like 3 or 4 of em, ranging from 150 to 210...
  5. widmod
    widmod Minimodder
    9 Oct 2006
    i supose 21 on the board description diagram is the power and reset switches and not a second RS232 Port? somehow it does look more like switches than a pinout... :hehe:
  6. samkiller42
    25 Apr 2006
    Did you guys ever manage to get a stable EVGA borad, i know when i got mine, Tim went through 3 of the damn things, and im still on my first.
    Good review guys :thumb:
    Sam
  7. Techno-Dann
    Techno-Dann Disgruntled kumquat
    22 Jan 2005
    Second the motion... A good review, though, even if it's basically the same hardware the third (?) time around.
    Out of curiosity, are the rounded IDE cables the same as the ones from the EVGA package? They look round, but on the inside, it's just the ribbon cable that's been sliced into strips, so it doesn't bend worth beans?
  8. Guest-16
    Guest-16 Guest
    Urgh, I think we gave up in the end tbh, I havent seen one around for months. We've done other nforce 6 EVGA boards since though.
    Dan: 2nd ;) I can't remember the EVGA package but I've just checked and it's a properly rounded (and very colourful internally!) IDE cable.
  9. pendragon
    pendragon I pickle they
    14 May 2004
    thanks for the review! :thumb: ..this just makes my choice of 680i board harder :p heh ...too bad you couldnt include benchmarks with 8800's vs 7900 .. oh well :)
  10. Guest-16
    Guest-16 Guest
    Well Tim does those in Gfx reviews :)
  11. Tim S
    Tim S OG
    8 Nov 2001
    I think the other issue is that bit-tech only has the one 30" screen and the numbers on a pair of 8800s at 1600x1200 would be pretty pointless because they'd be stupidly high. :)
    That said, I do want to upgrade our graphics cards for mobo reviews at some point because, yes, the 7900 and X1900-series cards are getting a bit long in the tooth now.
  12. pendragon
    14 May 2004
    Yea.. I'm just being selfish.. heh :D
    I suppose... but who doesn't love stupidly high numbers!? :D
  13. Nature
    Nature Minimodder
    21 Nov 2005
    Who does the mobile graphics reviews? I've yet to see any review for the new 8xxx and 2xxx series cards from Bit-tech. And other sites just don't compare with that bitty-techy quality :thumb:
  14. Tim S
    Tim S OG
    8 Nov 2001
    We're in the process of running the numbers for a review on the mid-range GeForce 8 and HD 2000 series cards. ;)
  15. DXR_13KE
    DXR_13KE BananaModder
    14 Sep 2005
    great :D
  16. DrewBear11
    DrewBear11 What's a Dremel?
    30 Sep 2006
    Treated myself to this
    Very nice board, really like it, however mine didnt come with any nuts/bolts/whatever and didnt have any motherboard stand offs.
    Also missing a drivers cd.....
    Moving on, only real problem is that it will not work with my xfi extreme gamer, blue sceen's, locks up.....
    can anyone shed any light on this, or is this an issue with any other 680i's ?
    Cheers
  17. Fused
    Fused Minimodder
    19 Jun 2007
    I also bought this as I thought it matched with the XFX 8800gts 320mb XXX i purchased
    Mine didnt have a drivers cd either :sigh:
    (No nuts and bolts either but i wasnt expecting ne, shud I have been? (plenty came with my case neway))
    I have a creative x-fi extreme gamer and works perfectly fine installed the drivers after loading windows and that was it. Im assuming youve checked your xfi extreme gamer was fine on another system?
  18. completemadness
    completemadness What's a Dremel?
    11 May 2007
    Maybe they want you to go on the site to get the drivers, because by the time u install them off the CD they are usually out of date anyway
    i haven't seen a motherboard come with nuts/bolts, most likely because that is all done with the case
    probably because the standoffs depends on the case, and the nuts depend on the standoffs, so it makes more sense to put the nuts/bolts with the case and just give you a motherboard
  19. Guest-16
    Guest-16 Guest
    Mobos don't come with nuts and bolts, that's a case thing.
    You should have had a driver CD in the envelope thing though.
  20. DrewBear11
    30 Sep 2006
    Ah right, yeah maybe i was expecting too much for it to come with extra bolts and standoffs.
    I was getting blue screens with the xfi, with the drivers off the cd, i havnt tried newer drivers with the card yet, maybe i will in the next few days.
    Is there anywhere i can request a driver cd or anything, because i couldnt find specfic drivers for that exact board on the xfx site..
    cheers
Tags: Add Tags
