Hardware XFX Triple Display Monitor Stand Review
Discussion in 'Article Discussion' started by arcticstoat, 24 Jul 2011.
  1. arcticstoat
    arcticstoat Minimodder
    19 May 2004
  2. greigaitken
    greigaitken Minimodder
    26 Aug 2009
    all i have to do now is carefully pry off those bezels
  3. Big_malc
    Big_malc Minimodder
    7 Sep 2010
    Given the choice between this and a cheaper much better designed Ergotron stands I now what one I would pick and its not the over priced less functional XFX
  4. Jipa
    5 Feb 2004
    Damn that looks so tacky :(
  5. Guest-23315
    Guest-23315 Guest
    No shots with screens installed?
    Bit-tech I am dissapoint.
  6. p3n
    p3n What's a Dremel?
    31 Jan 2002
    Routeing?
  7. samkiller42
    25 Apr 2006
  8. Toka
    Toka Minimodder
    19 Nov 2006
    Perhaps a shot of it with some cable routing and, you know, monitors attached?
    I bet we could get along just fine with only 2 shots of the bare frame.
  9. User-sam
    User-sam When in doubt, follow your nose.
    10 Apr 2010
    Looks impressive but £320! I could get all 3 monitors for that.
  10. [USRF]Obiwan
    [USRF]Obiwan What's a Dremel?
    9 Apr 2003
    I have 3 monitors on my desk. And I can route my keyboard, mouse, headphone, usb hub, mini and micro usb cable and mic cable and center speaker between them and it cost me nothing.
    This is ridiculous, all dual and triple monitor stands are way overprices. And not even showing it with all the monitors attached either horizontal or vertical in this review is worthless. this whole review is a poss.
  11. Star*Dagger
    Star*Dagger What's a Dremel?
    30 Nov 2007
    Triple monitor is the new standard for Gamers, please do not miss the most significant advance in Gaming since the breaking of the 21 inch barrier!!!
  12. TAG
    TAG What's a Dremel?
    7 Aug 2002
    Which ergotron model are you referring to?
    To my knowledge you need to mix match ergotron parts to get something similar that works with 24".
  13. SchizoFrog
    SchizoFrog What's a Dremel?
    5 May 2009
    And not a single picture of the frame in use in dual or triple monitor mode. I mean really, just one picture of a blank frame is enough... Who is going to have it sitting there without monitors on. Another half arsed review in my opinion.
  14. TAG
    7 Aug 2002
    @samkiller42
    The novatech will probably eventually sag and you won't be able to lift the side monitors to compensate.
  15. SlowMotionSuicide
    SlowMotionSuicide Come Hell or High Water
    16 May 2009
    +1 to this, also at least here in Socialist State of Finland the Ergotron stuff costs a fortune. You're easily spending this much for a single monitor stand. Granted, we got plenty of Ergotron stuff in our control room at work, and those are definitely premium pieces, absolutely high quality stuff. Too bad I can't justify spending more on a stand than my monitor...
  16. barndoor101
    barndoor101 Bring back the demote thread!
    25 Oct 2009
    erm, nope. iv got one of these and its coping fine, 1 year after purchase.
  17. 3lusive
    3lusive Minimodder
    5 Feb 2011
    It seems way overpriced considering one of these will serve the same purpose (you may need to buy additional long arms if your 3x monitors are 24", although I'm not too sure.). Either way its much cheaper than the XFX and is a clamp design which will probably be sturdier than the one used in the review.
  18. improprietary
    improprietary FT03 is a bitch to watercool
    13 May 2011
    i've seen a few monitor stands like this and everyone of them says they support 24" but never if its widescreen 24" or 4:3
  19. M7ck
    M7ck Ⓜod Ⓜaster
    28 Mar 2009
    I think it looks cool, not tacky at all.
  20. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
    Though it's nice to have the extra features here, it's kind of a shame that it all plugs into a gigantic base. People get these stands to free up their desks, not enslave them XFX.
Tags: Add Tags
