I have emailed Xigmatek asking whether the handles on their Aquila case are removable as well as the front drive cage being removable although it looks like they are both riveted, anyone know if this is the case and how do you de-rivet a case? Link to case: Xigmatek Aquila
definitely removable cage looks to be riveted to the base for the mobo and the handles, I can only see, the 4 rivets at the back which means front is either also riveted or screws. de-rivet you use something like a drill with a bit same size as hole of rivet think on cases it's maybe a 3mm
